How are O2's connected?
Old Mar 19, 2003 | 06:20 PM
bad1LEz's Avatar
New O2's installed last April. Just Seafoamed, first time since I had the car. Should I change the O2's? Don't notice anything wrong. How do they connect, with plug in type connectors(like MAF Sensor) or hard wired?
Old Mar 19, 2003 | 06:21 PM
Greasepunk's Avatar
like MAF sensor, just a clip, but they should be fine Seafoam is O2 safe if you use it right.
Old Mar 19, 2003 | 06:25 PM
bad1LEz's Avatar
Thanks, that's what I thought. It says it won't foul O2's on the can. I've heard of some people saying they had to change them out. Like I said though, don't feel anything wrong so far. And I'm pretty sure I used it right. Found out I have one he!! of an exhaust leak!
Old Mar 19, 2003 | 06:28 PM
FreByrd2's Avatar
i seafoamed my car with 117k miles for the first time. My 02's were just fine afterwards.
Old Mar 19, 2003 | 06:41 PM
Euclid's Avatar
car's got 80k on her...
is seafoam worth the $$$?
both performance and maintenance wise
Old Mar 19, 2003 | 06:44 PM
Greasepunk's Avatar
YES! it is. You should notice a difference. Make sure you follow the instructions though.
Old Mar 19, 2003 | 06:47 PM
Euclid's Avatar
How much does it typically cost? Where to get it? What's the process consist of?
Thanks!
Old Mar 19, 2003 | 06:51 PM
Camarocks's Avatar
Thanks!
It's around $7/can. As far as I know, neither Auto Zone or Advance carries it. I bought mine at a local Napa. The process basically consists of introducing it through the brake booster vacuum line into the intake until it almost stalls. It makes a lot of smoke and usually fouls your plugs, but gets rid of a lot of carbon buildup in higher mileage motors.
Old Mar 19, 2003 | 07:24 PM
Euclid's Avatar
So I should wait till i do plugs/ wires to do it?
Old Mar 19, 2003 | 07:27 PM
Greasepunk's Avatar
I think my plugs were cleaner afterwards. I recently pulled them and they looked almost brand new. My car had 102k miles on it when I seafoamed it.
Old Mar 20, 2003 | 12:27 AM
cals400ex's Avatar
the seafoam is o2 safe. however, i think what they are getting at is that when using seafoam you clean. this means the exhaust will be dirtier and these particles can shorten the life of the o2's. my o2's needed replaced anyways. the new o2's made more of a difference than seafoaming the engine for me.
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
Bxlt1
Sep 10, 2015 08:16 AM
