can someone with LT1 edit or tunercat help
Old Mar 19, 2003 | 06:13 PM
Fbody1's Avatar
Talking can someone with LT1 edit or tunercat help
I would like to know if anyone can tell me if I can edit my pcm, I have a obd1 94 lt1 m6with a lt4 hot cam a friend did edit my pcm with a program that he said would work with the hot cam he thinks that it is a ed wright program i am debating on getting the lt1 edit or the tuner cat if i have this program (ed wright)will either program be able to edit it?or will i have to start from a ground up and re program?can some one please help me
thank you
Old Mar 19, 2003 | 07:06 PM
Fbody1's Avatar
I know someone on here will help me , or will they ? I thought I read some where that you could not edit someone else pcm program(ed wright program I think) need to know if anyone has a ed wright program , and used lt1 edit or tunercat to make changes , and how can I find out if mine is a copy of that program
GetaZforgetGT's Avatar
If your buddy uploaded the program for you then you should be able to edit it on your own once you get the tuning software.
Now if the tune was uploaded by Ed he more than likely locked the file. Ed does this to prevent his work from being used without his permission.
You shouldn't have a problem editing the file.
Old Mar 19, 2003 | 07:12 PM
Fbody1's Avatar
thank you jeff, wich do you have lt1 edit or tunercat , do you know wich one is the most user friendly?
Old Mar 19, 2003 | 07:34 PM
Dr.Mudge's Avatar
If you know how the car works, they both do the same thing. I prefer Tunercat, in large part because of the price, and to me it just looks better. Plus obviously Tunercat is not VIN locked, although that is not an issue for many people.
I am not aware of any Ed Wright Hotcam files floating around for 383 cars, but I could be wrong, timing is different for a stroker.
Old Mar 19, 2003 | 07:42 PM
I have tunercat. I like it for all the same reasons that doc said.
I'm still learning but getting better with it.
Its not as "GUI" as LT1edit but for the money difference I really don't care.
Old Mar 19, 2003 | 07:43 PM
Fbody1's Avatar
my car is not an 383 it is a 355 , I'm kinda new to this where do you find programs to try ,and do you know if there is any for a 355 , I don't know if mine is for a 350 w/hot cam or a 355 w/hot cam , also have a few other mods ,all the norm bolt on mods
Old Mar 20, 2003 | 09:21 AM
All_Z_Way's Avatar
Look down the page for some links to .bin and .lt1 files.
Old Mar 20, 2003 | 10:12 AM
Dr.Mudge's Avatar
383 and 355 timing is not going to be the same. Ed does lock down some of his programs, hopefully you didn't just lock up the computer.
Old Mar 20, 2003 | 11:14 AM
Am I right when I say that Ed Wright didn't do the tuning?
Your buddy did.
I would advice you to use the E.W. tune to study and learn from because all cars are going to respond differently to a particular tune.
The good thing is that you can get a general direction to follow and it will help you get yours tuned with a lot less Trial and error.
Old Mar 20, 2003 | 05:05 PM
Dr.Mudge's Avatar
If the cubes and heads/cam are similar then the timing SHOULD be pretty darn close, and that is a + to using a baseline tune. Just play it safe, especially with WOT since AF could be way off, or timing could be as well, but in general the timing should be close and you can figure that out slowly on the street.
Old Mar 22, 2003 | 12:37 AM
tjwong's Avatar
Tuner Cat is the way to go price wise and there are some tables that are accessible in TC that are not accessible in Edit. Price wise TC is the way to go as it allow for unlimited use for programming unlimited numbers of PCMs and ECMs for other applications. LT1 Edit is a good product but is locked to one PCM. Some say Edit has a more user friendly interface but I personally find TC easier to use. One thing taht Edit does that TC will not is when making a gear ratio change for example going from 3.42 to 4.10 axle gears.
Edit will automatically make all the necessary edits to the shift tables. TC will not do that. I have found that when making that change in TC the car will not shift properly after the gear change. Edit makes around 600 table entries automatically in all the shift tables when making a rear axle ratio change. I use Edit when I need to make a gear change for anyone needing it, for all other operations I use TC.
For either set of software you will need a programming cable which is available from Andy at:
WWW.AKMCABLES.COM
If you have a locked Ed Wright programmed PCM you can open it with TC, you can read it and look at the tables but because he locks it you won't be able to reflash your PCM with that file if you try to edit it. But if you send me the file I can usually find his locks and repair it so it can be read and edited again. I have fixed several of them, as long as it is a 84/95 F or Y body I can most likely fix it.
Old Mar 22, 2003 | 10:01 AM
Fbody1's Avatar
thank 's I'm going to order the cable today , so it will be a few day's , I've not to buy any softwear yet( tc or lt1 edit yet ) my freind said that he will make me a copy of his disc I'm not sure wich one he has ? can he do that and it will work for me ?any way I will have to have one or the other , if it is a ed wright program and it is locked I will send it to you to unlock it . thank you
Old Mar 22, 2003 | 11:00 AM
Dr.Mudge's Avatar
It sounds like your asking advice on stealing software, you and your buddy should figure that out between yourselves.
Old Mar 22, 2003 | 11:17 AM
tjwong's Avatar
You are better off purchasing the software be it TC or Edit. One thing is that if you purchase it there is support from both and support is good with both products if you have a problem.
Plus TC is has a authorization code so even if he gives you a disk the software may not work correctly and you can take a chance of corruption which will cause you more headaches than $90 for software that is licensed.
Just a bit of adivice.
