What Bolt-ons am I missing?
Old Mar 19, 2003 | 10:53 AM
InGodITrust's Avatar
You can see my current mods in my signature! I was wondering if I have missed any 'easy' bolt-ons or other mods that should be done? Either engine, clutch, tranny, rear-end, suspension, etc. If you could list the mod and why it would benefit me (+hp or <et), that would be great!!!!
Thanks for you help!!!
Old Mar 19, 2003 | 11:10 AM
95_RipperZ's Avatar
Switching to longtube headers would give you some HP especially b/c of your head work and cam.
SUspension wise I think it would be wise to invest in some LCAs, SFCs, and relocation backets. Then also some slicks.
Next would be some weight reduction
Old Mar 19, 2003 | 11:18 AM
GREGG 97Z's Avatar
SFC's - no hp but will really stiffen the car up, bolt on or weld
UD pulley - shown to gain 5rwtq & 1rwhp
TB bypass - free, and around 5rwhp
LS1 Driveshaft - reduce vibration if you still have stock steel, possible hp gain
Just a few ideas
Old Mar 19, 2003 | 11:23 AM
teke184's Avatar
since you have a cam/heads you could probably gain 5-10 hp from getting 52mm throttle body, either have your stocker bored by someone like NOMAD or buy an aftermarket unit.
how bout upgrading to 1.6 rockers?
bigger injectors?
Old Mar 19, 2003 | 11:29 AM
TedH's Avatar
I would go for one of these: http://www.wolferacecraft.com/pages/...rt/weld-in.htm
Because it will stiffen the car up and make it safer at the same time without having to add suspension components. If you race frequently I can see a 12 bolt in your future too.
Old Mar 19, 2003 | 08:55 PM
my94blackz's Avatar
Mass air sensor good for some, bolt on a nitrous system!!
Old Mar 19, 2003 | 09:00 PM
tfs95z28's Avatar
What kinda gear ratio you got in there??? You can easily find a whole rearaxel on the board for about 250-300. A lot easier and cheaper to do than a gear install. Might wanna think about that. Definitely go with some LCA's too. They help out a lot.
Old Mar 19, 2003 | 09:08 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
12 bolt, SFC's, LCA's.
Chris
Old Mar 19, 2003 | 10:53 PM
smokindastangs's Avatar
58mm TB
MAF
gears....3.73, 4.10
TB bypass
Old Mar 20, 2003 | 01:48 PM
I've currently got 3:42 gears. I have been thinking about getting some 3:73. I really have to slip the clutch with 3:42 to get a decent launch.
I think I'll also go with the LCA and Relocation Brackets as well!!
Old Mar 20, 2003 | 01:57 PM
dabear95's Avatar
Torque Arm
Old Mar 20, 2003 | 02:56 PM
joeSS97's Avatar
CSI water pump.It does free up a good amount of HP.I drive mine daily
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
