2 quick mod questions...
Old Mar 18, 2003 | 07:56 PM
Got-LT1's Avatar
First, does anyone know where I can get 90/10 front shocks for a 93 Z28?
Second, will an adjustable fuel pressure regulator help raise my horsepower at all?
Thanks for your time guys.
Old Mar 19, 2003 | 12:30 PM
Got-LT1's Avatar
Anyone?
Old Mar 19, 2003 | 12:33 PM
95TA8280's Avatar
Re: 2 quick mod questions...
That is an ongoing debate on this board. Do a search. From what I understand, the AFPR will work for a very short time, then your computer will realize this, and switch back.
Old Mar 19, 2003 | 01:30 PM
94F1Z28's Avatar
Re: Re: 2 quick mod questions...
On a 93 a AFPR is a very good mod and the computer will not compansate for the difference,on the 94-97 mass air cars it will.Also you can get the shocks from summit and probably alot of other places but i know for sure that summit sells them.
Old Mar 19, 2003 | 01:38 PM
COMNBYU's Avatar
bumping up the fuel psi on any stock car is not going to give you a major gain in hp. once your mods start, or you get a PA, then your psi is more critical and usually requires some pretty signicant tuning to get the most out of your set up. on a stock car, i wouldnt waste my money.
for the shocks, as said, Summit sells some and im pretty sure Jegs does as well.
jon
Old Mar 19, 2003 | 01:45 PM
94F1Z28's Avatar
Well if the car is fairly stock then lowering the fuel pressure will usually add 9-12 hp and about the same amount of torque,it is a very good mod and as you mod the car further it will be a great tunning devise,in my opinion a AFPR is a manditory mod on a 93.
Old Mar 19, 2003 | 01:47 PM
hairbear21's Avatar
Definately go with the AFPR on a '93. The ECM will not compensate for the change in fuel pressure like it will on 94+ cars. That is why people will say not to do it. Go to www.ws6.com he gained 16HP by leaning out the mixture. But because his was not a 93 and had a PCM, it saw the change and set the a/f mixture back to what it should be.
IndyZman
Oct 22, 2015 02:17 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
DelSoto
Sep 19, 2015 05:31 AM
NewsBot
Sep 14, 2015 09:20 AM
