Rod and main cap torque
Old Mar 18, 2003 | 06:23 PM
INFERNO's Avatar
I am rebuilding a stock 93 Lt1 bottom end. Two questions, what lube should I use on the bolts, I was going to use normal 10-30 oil. I am useing all stock fastners. I need the engine main cap bolt torque and the rod cap bolt torque. Thanks.
Old Mar 18, 2003 | 06:42 PM
anaik's Avatar
13-30 is good
http://www.bfranker.badz28.com/fbody/torquespecs.htm
Old Mar 18, 2003 | 07:02 PM
Mindgame's Avatar
Lightly coat the threads ("light" means the bolt should not be dripping with oil) and underside of the head of the bolt.
Follow the specs you'll be fine.
One question though... are you using factory bolts or ARP, etc.?
-Mindgame
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
carl.froehlich
Mar 13, 2015 12:38 AM
