Rad Hoses
Old Mar 18, 2003 | 06:19 PM
Gripenfelter's Avatar
Rad Hoses
Who makes a good set of aftermarket rad hoses and lines?
I have an aftermarket rad and thought I should swap out the hoses.
Goodyear High Miler?
Braided?
Old Mar 18, 2003 | 06:25 PM
n2ceptor's Avatar
I know that good year is pretty good... They are usually used in police packages.... But they dont make it for the 93' camaro only 94'-97... The rad hoses are different....
Summit part # GTR-5006.....
If you got the money and time you could make them out of braided.. They are the strongest....
93Z Will
Old Mar 18, 2003 | 06:39 PM
Mtrhds94Z's Avatar
Goodyear Hi Miler set is good [except that one hose is missing! but that can be worked around]
It has 10 of the 11 hoses...
While it is for the 95-7 configuration, you can change a 93-4 to the later hoses, with the kit, [and you also need the 95-7 'bleeder pipe' as opposed to the 93-4 'bleeder tee']
I did it on my 94... gets rid of that funny molded tee on the drivers side radiator hose, also it allows getting rid of the 'coupling' needed for 93-4 TB bypass...
A bit tricky to do but I felt that a 94 was 'ready' for all hoses to be replaced..
The kit even has all [except ONE that is!]of the heater hoses[ you replace those by Dremeling off the crimped clamps]
Charlie
Old Mar 19, 2003 | 07:44 AM
Thanx guys.
Who sells braided rad hoses and who sells goodyear?
Old Mar 19, 2003 | 08:27 PM
ttt
Old Mar 19, 2003 | 08:36 PM
n2ceptor's Avatar
www.earlsperformance.com for braided
Old Mar 20, 2003 | 05:56 AM
Mtrhds94Z's Avatar
Originally posted by Gripenfelter
Thanx guys.
Summit part # GTR-5006 for the Goodyear Hi Milers..
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
