Anyone have an SVO lock up??
Old Mar 18, 2003 | 10:48 AM
CanadianZ's Avatar
I have switched to SVO's from stocker's. (still 24#'s) I have a 5176 NOS kit and wanted to know if anyone has had a problem with the SVO's ever locking up. Just want to be sure the FPSS and window switch will be enough to run the juice safely.
CanadianZ
Old Mar 18, 2003 | 02:38 PM
Derrick Redd's Avatar
I had a stock injector lockup once. Switched to SVO's and it hasn't happened again.
Old Mar 19, 2003 | 09:43 AM
OutKast's Avatar
when I was shopping injectors it was all the craze about the SVOs because they are supposed to be much less susceptable to lockup. I'm running the 24# svo with the TNT wet kit and have never had a problem other than running 100% duty cycles Time for the 30s
Old Mar 19, 2003 | 03:42 PM
CanadianZ's Avatar
There's no real need for SVO's if you are running a wet kit. The reason they are recommended for the dry kits is because the FP is increased to ~80psi in stead of the stock 43psi. At the higher FP stockers tend to lock up while the SVO's usually don't.
24# SVO's are rated at 39psi so when tuning your car they should be set at about 26#'s to account for the diff in FP.
CanadianZ
Old Mar 20, 2003 | 10:19 AM
Mikael's Avatar
I've pushed SVO's over 100psi without problems.
Aaront810
Aug 29, 2020 09:34 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28cam1993
Sep 9, 2015 04:08 AM
