Differences between 94 & 2000 check engine lights
Old Mar 18, 2003 | 01:26 AM
greenZ94's Avatar
OK, as you may know I am having a few problems. Well in my 94Z turning the ignition off turned the check engine light off and it would not come on when the car was restarted. Now I am getting a check engine light in the 2000 and it comes on immediatly when the car is started, long before any diagnostics could have been performed. My question is, how do I reset the check engine light? Will resetting it cause any problems, like loosing the original code? Does the car ever turn the check engine light off by itself (In my 94Z I could be cruzing down the interstate, the check engine light would come on for 5 minutes, then the light would go out, all without turning the key off. Also, should I buy a scan master or will a dealer's scanner be able to tell a lot more?
Old Mar 18, 2003 | 08:08 AM
PAGregSS's Avatar
Autozone can scan and clear the code for free.
Old Mar 18, 2003 | 08:45 AM
greenZ94's Avatar
Oh yeah, you the man Greg
Do I have to make an appointment?
Old Mar 18, 2003 | 09:06 AM
PAGregSS's Avatar
No, no need for an appointment. Make sure you write down the code so you can get an idea what might be wrong.
Old Mar 18, 2003 | 09:17 AM
stik6shift98's Avatar
yea write itr down and post it and we will tell you what is wrong...
and yea just go into autozone and tell them to run a sytem check and they will come out to your car right away...
Old Mar 18, 2003 | 06:30 PM
greenZ94's Avatar
Question Got the code p0122 TPS sensor range low
Any idea what this means? The car ran fine when the check engine light was on. I did not hear the fans on when the check engine light was on like I used to in the LT1, are there two difern't check engine modes? Like a limp home (Fans on and minimal engine sensors required) and a hey take me to the dealership so they can rip you off mode?
The weird thing is that the check engin light was not on when I restarted the car today after it sat for ~24 hours. Why did the check engine light come on right away yesterday when there was no cool down time but overnight it cleared, is this normal?
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
