no power in OD on the freeway, experts inside pls
Old Mar 18, 2003 | 01:03 AM
TMDZ28's Avatar
Question no power in OD on the freeway, experts inside pls
i was crusing down the freeway after i replaced my torn intake elbow, every time i cruise around 2200RPM, and i press the gas pedal slowly, the RPM went right up to 3400RPM, but the power wasnt there. after it reached 3400RPM, it went down to 3000RPM, and the power came a little bit. not like it used to. usually, after it went to 3000RPM, it would push me on the back of my seat.....what gives? is it my plugs/wires? or something else? a bad o2 sensor came to my attention.....please list me all the possibilities guys....thanks a lot
Old Mar 18, 2003 | 03:26 AM
Pinchy's Avatar
If you just replaced the elbow I would first make sure that the little blue L-shaped tube is plugged back in. It goes in the small hole in the intake elbow bend. It can get squished out of the way and forgot about very easily.
Old Mar 18, 2003 | 03:33 PM
TMDZ28's Avatar
everything is pluged
Old Mar 18, 2003 | 03:40 PM
Bryan Smith's Avatar
When you get on it, is there any black smoke, does the engine stumble at all? I had a torn elbow and getting off an exit sucked. Once I replaced both O2's and all 8 plugs she felt like brand new again.
You should start getting SES soon if it is your o2s.
if not, check one plug, see what it looks like. I know mine were horrible after letting all that unmetered air in.
Old Mar 18, 2003 | 03:57 PM
TMDZ28's Avatar
i think i saw an oil in my #1 plug...can this be the cause?
Old Mar 18, 2003 | 06:15 PM
TMDZ28's Avatar
i also think my stall converter might be one of the cause.....because today, i push it to WOT. i was driving in OD without pushing any gas, then suddenly i pushed it to wot. the rpm went up to 3500RPM without producing any power, a second after that, the power started to came in...i have a stock stall converter, it should not acting like this.....
Old Mar 18, 2003 | 07:46 PM
TMDZ28's Avatar
TTT
Old Mar 21, 2003 | 12:14 AM
TMDZ28's Avatar
is my tranny sliping?? because i had the tranny rebuild about 5-6K miles ago, and the very first day, the solenoid crisp. so i'm afraid this is the cause
Old Mar 21, 2003 | 12:33 AM
viperkiller's Avatar
could be tranny see if trans fluid is brown or smells burnt should be deep red or pink if on;y one gear sounds like OD is bad most tranny shops are more than happy to check
Old Mar 24, 2003 | 04:51 PM
TurboSS's Avatar
Sid,
The trans u have in that F-body is trash!
Sell the car and by a z28 or Firebird with a stick!
TAD
F'n1996Z28SS
Aug 23, 2023 11:19 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
XtremeLt1
Sep 13, 2002 08:50 PM
