AS&M TB, bigger injector upgrade
Old Mar 17, 2003 | 03:02 PM
OrangeIROC's Avatar
I already did a search about this stuff, i got some mixed opinions.. As u can see from my sig, i am installing a LT1/T56 into my iroc, it will have all boltons, 224/236 cam, no AC, no AIR, it will be tuned by PCM4less.. I will be on the bump as for my fuel system from what i understand from other posts so i want to upgrade the TB. some on here like BBK, some like Holley and i've read about problems with both.. Others used the AS&M and i haven't seen anything bad about it so i think i'm gonna go for that one. Now they have a 52mm & 54mm, which should i get?, Nitrous is in the equation (100-150shot) and the main-MAIN reason for upgrading.. Next is the injectors, i think 30lbs would be the correct ones, i did the equation for them and i came up with 29.xx, could have screwed up but i think i did it right, any thoughts?
Mike
Old Mar 17, 2003 | 03:34 PM
BUBBA's Avatar
I'd suggest going with the AS&M 52MM unless you are go with juice or boost (then maybe a 58MM).
The 54MM would be nice, but the 52 will be cheaper if you get a stocker on the cheap to use as a core.
The intake is already sized for a 52MM also.
I did this and found that the AS&M bolted right up with no problems. Nice chrome cover too.JMHO
Old Mar 17, 2003 | 03:38 PM
joeSS97's Avatar
You should upgrade the fuel pump as well.Dont want it to lean out on ya.I would go with the 52mm.30 lbs injecters sound good too.
Old Mar 17, 2003 | 04:06 PM
OrangeIROC's Avatar
Sweet sounds cool to me.. AS&M and 30lb injectors are it!!
Old Mar 17, 2003 | 04:16 PM
96z's Avatar
96z
30lbers should be good mike, what will also influence your choice will be whether or not it will be a dry or wet N20 system.
Like mentioned above if you go 54mm youll have to port your intake some.
QuickSilver02
Apr 7, 2015 11:12 AM
grabbem88
Feb 22, 2015 11:16 AM
tbyrne
Jul 2, 2002 05:37 PM
