checking the coil
Old Mar 17, 2003 | 01:31 PM
dajohns2's Avatar
checking the coil
are there any fix it/install guides for testing the coil. for example brent frankers home page. i looked under his fix it page, but did not see anything refering to checking the coil with a multimeter to see if it has gone bad.
Old Mar 17, 2003 | 01:38 PM
Dr.Mudge's Avatar
You want to use the ohm-meter portion to check resistance. You can do the same with plug wires.
Old Mar 17, 2003 | 01:41 PM
Greasepunk's Avatar
Detach the primary electical connector from the coil. Using the ohmmeter low scale, hook up the ohmmeter leads to the primary terminals on the ignition coil. (the 2 slots) The ohmmeter should indicate a very low resistance value. If it doesn't replace the coil.
Its hard to explain without showing u pictures or hands on. Hope this helps a little though.
Old Mar 17, 2003 | 02:38 PM
You can also test by removing the coil wire and use your ohmmeter to test between the coil wire (secondary) terminal and to each of the 4 primary terminals, one at a time. Each reading should be ~8100 ohms on a stock coil.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
