Stock Z28/SS numbers
Old Mar 17, 2003 | 10:51 AM
Sal Collaziano's Avatar
Wondering what one could expect for a 0-60 and 1/4 mile time on a stock atuomatic Z28 and/or Z28 SS..
Thanks...
Old Mar 17, 2003 | 12:07 PM
Snakekiller's Avatar
on a Z28 it should be about 13.2-13.5 in the 1/4 mile depending how u drive and i believe 5.1 seconds 0-60. on the ss will be a little bit faster but not much at all. im not sure about the exact numbers though for the ss
Old Mar 17, 2003 | 12:11 PM
tomslawsky's Avatar
The stock SS should actually be a tad slower, as it is usually loaded up with extra weight options.
Old Mar 17, 2003 | 12:15 PM
Interesting.. Thank you.. I guess the SS has traction control and the Z28 does not? Would that be one of the options?
Old Mar 17, 2003 | 03:34 PM
stik6shift98's Avatar
no....z28 have traction control as well
Old Mar 17, 2003 | 04:39 PM
jd13's Avatar
Almost every option that was available on the SS was available on the Z28 besides the "SS" package.
Traction control was an option available on all the cars. It's just a simple button/switch thingy.
Like Tom said, in theory, a Z28 with no options would be the faster of the cars because of less weight. But in reality, every engine/car will dyno slightly different numbers, that is just the way it is.
Old Mar 17, 2003 | 07:40 PM
i agree bout the z28 being faster....
if u think getting an ss will make u go faster your wrong...all an ss is is apperance and more cash
Old Mar 17, 2003 | 09:05 PM
psychocabbage's Avatar
yeah mine is silly light! 4490 with 3/4 tank of gas and everything inside (spare and whatnot)...
Old Mar 18, 2003 | 01:00 AM
AL SS590 M6's Avatar
Moderator
Even the base SS is more that just an appearance package. It also has different shocks, springs, front swaybar, tires, and wheels. It's more of a handling/appearance package.
And yes none of this makes it faster.
But let's not be misleading.
Old Mar 18, 2003 | 03:30 PM
MRZ28HO's Avatar
I hope you meant to type 3490 and not 4490. Otherwise, that is a porker. My A4 SS (with a 1/4) weighed in at 3460, fully optioned (T-Tops and all).
Hardtops will be the faster ones, regardless if it is a Z28 or SS. The stripper Z28 were among the lightest, but you could have ordered a stripper SS (some years) as well, which rivaled the performance of the (light) Z28s.
Old Mar 19, 2003 | 01:39 AM
yeah.. my typo! heh oops!
I mean 3490... I figured it to have about 12.5 gallons of gas in the tank.. spare and whatnot still in car.. everything I would normally have.. (i still havent even seen my spare).. T-tops are on my car as well.. so I would assume that with only 3 gallons of gas at 8lbs a gallon.. should bring my car to 3420ish range.. so 3300's are possible if I were to strip it down some...
with me in the car add 200lbs.. If ever there was a reason to lose weight.. hehe
Old Mar 19, 2003 | 01:08 PM
guywidiroc's Avatar
Since times are what are asked for, Ill try and stay on topic here. Times are in sig.
DirtyDaveW
Dec 1, 2016 05:37 PM
canbaufo
May 25, 2015 12:01 PM
Roadie
Feb 16, 2015 10:34 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
