How much power from a 355?
Old Mar 17, 2003 | 10:08 AM
95TA8280's Avatar
I see a lot of people turning their 350s into 355s.....how do you do it and how much HP is to be gained from it?
Old Mar 17, 2003 | 10:10 AM
Mikael's Avatar
Its the CI you get when your bore a stock 350 block .030 over. It doesn't gain anything by itself, its for people who have rebuilt their motor.
Old Mar 17, 2003 | 10:32 AM
Larnach's Avatar
5hp at the most.
Old Mar 17, 2003 | 10:36 AM
teke184's Avatar
the advantage of a 355 is a nice smooth cylider bore wall for good ring seal.
the power comes form internal components, forged etc...and what kind of heads/cam you top it all with
Old Mar 17, 2003 | 10:39 AM
JohnsSS's Avatar
355 is more for compression changers and rebuilders. A friend of mine had a 94 z28 that he did it to. He had all the exact same mods as I did except he replaced a few more internals than I did. Like the pistions. Same heads and intake and port/flow same cam specs. He put 378 rwhp and 352rwtq, I made 381 rwhp and 349 rwtq. So you can see that the 355 is not much of an advantage on a 350.
If you want to see real results go to a 392+ Then you will make some real numbers. Good luck with your results.
Old Mar 17, 2003 | 11:07 AM
94SLUG's Avatar
How many dollars do you want to invest, and what are looking for.
Old Mar 17, 2003 | 11:43 AM
96z's Avatar
96z
I was always told from a 350-355 there is a 2-3% power increase. So say you had 400 HP with a 350, with a 355 youd make "around" 408-412HP all things being equal.
Like mentioned earlier its done mostly to clean up the bores and for a chance to but in forged internals to handle lots of spray or boost.
Old Mar 17, 2003 | 11:48 AM
sweet94Z's Avatar
My 355 is basically putting out out the same hp as it was when it was a stock short block. It started smoking so I rebuilt it with stock compression etc. but went with 6.0 rods & kb pistons & saw no improvement on track times. 355's are, as stated above,for people who had to rebuild or people how dicide to go forged to hold crazy amounts of power whether it be produced by good heads cam etc, or a power adder. Not near as much power can be found in a .030 overbore & compression change as in the top half of an engine. 355's aren't worth it IMHO when your stock bottom half is in good condition & your after no more than 375/400 rwhp(I have no clue what your goals are).
LeftoverChinese
Jan 14, 2024 03:03 PM
MadMav
Jun 8, 2015 11:38 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
InfernalVortex
Jan 17, 2015 09:35 AM
XtremeLt1
Sep 13, 2002 08:50 PM
