Cant get y-pipe off...
Old Mar 17, 2003 | 12:39 AM
Dragon Racing's Avatar
I'm trying to get my y-pipe off from my stock manifolds so i can install my headers, but i cant get the thing off. It came off from the cat back easy. I took the 3 nuts off each flange where it connects to the manifolds, but the flanges dont move after i've removed the nuts. Is there something i've missed here? I figured that after i removed the nuts that the flanges would come loose and slide off, but they wont budge. Have i missed something? Or are my flanges just stuck? Thanks for any help!
Old Mar 17, 2003 | 01:00 AM
97CamaroZ28R's Avatar
ACA Performance is right, the only thing holding the flanges together is rust. Try hitting the flanges with a hammer. If that doesn't work , try spraying the flanges with WD-40/ PBlaster and then repeat with hammer.
Old Mar 17, 2003 | 02:55 PM
Mr Freeze's Avatar
i've used PB Blaster on rusted stuff...much, MUCH better than WD40 (IMHO). it's only a couple bucks from Discount Auto, or some of the other auto parts stores...
if you've got a day or two, spray it once and let it sit overnight...spray again next day.
travis
Old Mar 17, 2003 | 03:26 PM
PatriotTA's Avatar
travis
I agree that PB Blaster is pretty rock and roll, but if you don't want to spend the $4 per can (and it goes pretty quick if you got some rusty parts) you can just use come Coke. Get a can/bottle of Coca-Cola and spray it on the area. There's enough acid in there to break loose the rust and it works better than WD40, IMO. Hmmm, think about that next time you drink that stuff.
Old Mar 17, 2003 | 03:31 PM
FastZinTennessee's Avatar
That is odd, my bolts broke off on the flanges, all of them!! When I got the last one done the Y-pipe almost came down and busted me in the head Good thing there was something in the way stopping it from falling
Old Mar 17, 2003 | 03:32 PM
joeSS97's Avatar
Give it a couple good wacks with a heavy persueder(hammer)
Old Mar 17, 2003 | 04:04 PM
BUBBA's Avatar
Try blowing in its ear.
Old Mar 17, 2003 | 04:15 PM
Gripenfelter's Avatar
Soak in WD40 and use a crowbar and a hammer to wack the flanges loose.
Old Mar 17, 2003 | 04:29 PM
BUBBA's Avatar
Liquid Wrench, Vice Grips and a cheater pipe.
Old Mar 17, 2003 | 11:52 PM
Alright guys, i finally got it off tonight! It wasnt nothing that a half can of PB Blaster, a pry bar, and a hammer couldnt remove . You guys all say you snapped your bolts and your flange fell off....Well, my bolts came off almost efortless believe it or not! Anyhoo, thanks for all the replies everyone!
Old Mar 18, 2003 | 08:10 AM
Mr Freeze's Avatar
that PB Blaster is some pretty amazing stuff, albeit a little expensive.
Travis
Quickss96
Jan 29, 2016 05:56 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Noer
Parts Wanted
May 4, 2015 04:58 PM
Dylan Latshaw
Mar 21, 2015 09:48 AM
