Fog Light Out
Old Mar 16, 2003 | 08:35 PM
Chevrolet Bailey's Avatar
Fog Light Out
Ive got a fog light out in my 97 camaro. Whats the best way to replace it. How do you get the lens off to change it.
Thanks in advance
Old Mar 16, 2003 | 08:44 PM
gb95zconv's Avatar
You dont...it has a bulb that goes in thru the back. I pull the pins on either side of the housing and take out the adjusting screw and then pull the housing out .
Larnach's Avatar
There is a small bolt on the side and a torx screw on the front that is spring loaded. Undo those, take out the housing and then take out the bulb. Water came out of mine, so did a bunch of glass from the shattered bulb.
EDIT: Plastic clip is on the side actuall, its kind of a pain in the ***.
Old Mar 16, 2003 | 11:42 PM
Prince's Avatar
I've just slid my hand down from above, between the washer fluid res. It does require withstanding some pain. Actually I too have a bulb out, and I think I'll try the above mentioned way instead.
Dave
Old Mar 16, 2003 | 11:44 PM
smokindastangs's Avatar
All of my friends have had bubs go out.....If I were you I would just put a whole new foglight in there instead of just replacing the bulb. If you choose to just get the bulb; either don't hardly use them, or get used to changing them.
Old Mar 17, 2003 | 10:10 AM
Larnach's Avatar
They last quite some time, I've had mine on the passenger side for over 115,000 miles, I just replaced the drivers side a few weeks ago... took about 5 minutes to do it.
Old Mar 17, 2003 | 05:28 PM
Really?? well i have quite a few friends w/ f-bodies and we all have tremendous problems with the fog lights.....maybe we are just really un-lucky!!
Alien
Jun 27, 2015 01:13 PM
PROJECT X
Apr 17, 2015 12:13 AM
Jlo
Feb 3, 2015 09:41 PM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
