crank bearing clearance
Old Mar 16, 2003 | 12:11 PM
INFERNO's Avatar
I have a 1993 Lt1 I am rebuilding. I went to the machine shop and had the crank polished and the block align bored. I have clearances of .0025 in on all five journals. They said it is Ok and they go has large has .0030 in. The haynes manual specs say maximum of .0022 in. Is this ok. Also what should the rod bearing clearances be? Thanks.
Old Mar 16, 2003 | 12:26 PM
Mindgame's Avatar
I usually use .0025 on mains #1-4 and .003 on #5. Helps in getting a little more oil to the thrust bearing.
I shoot for .0023-.0025 on the rods.
-Mindgame
Old Mar 16, 2003 | 05:58 PM
Ken95Z28's Avatar
I set mine up .002 across all mains, .0025 on the rods. I think the .003 is a little to much for the mains.
Old Mar 16, 2003 | 06:15 PM
Mtrhds94Z's Avatar
If you're concerned, get a set of STD and a set of .001 OS bearings and use half from each to close it up .0005
Old Mar 16, 2003 | 08:06 PM
Mindgame's Avatar
.003 is too much for #1-4, but not for #5. I don't know too many people doing it differently... at least not on a high-performance build.
For a performance build that sees a good deal of rpm and track time, .002 is too tight. But that's just my opinion.
-Mindgame
carl.froehlich
Mar 13, 2015 12:38 AM
Chevyguy358
Jan 28, 2015 08:04 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
dthomas
Aug 5, 2002 01:05 AM
