Camshaft Endplay
Old Mar 16, 2003 | 12:45 AM
Central PA Z's Avatar
Camshaft Endplay
I think I a problem here so I'm hopfull someone will be able to advise on this. Anyway.... I got my cam in and after I put the retainer plate back on, I still seem to have about 1/4" endplay in the cam. When I pull it forward (towards the retainer plate), the lobes of the cam seem to line up as they should with the lifter ports. When pushed back, they are again, approx. 1/4" off center. I don't seem to remember this drastic ammount of play in the cam after my other install.
I'm not sure on what device is to the rear of the cam to stop it, but it looks like it could be the freeze plug?? If this is the case, is it possible that when the machine shop installed the new freeze plugs, that he didn't insert it far enough into the block?? Thanks.
Edit: BTW, my heads are back and flow 278/197 @ .550 Should compliment my 230/242 just wonderful. :-)
~John
Old Mar 16, 2003 | 02:11 AM
sssalah's Avatar
This can't and needn't be adjusted with roller cams. Once the sprockets and chain are fixed there's no way that cam will move backwards and thae retainer wont allow it to mave forward.
Good luck!
Old Mar 16, 2003 | 02:25 AM
Originally posted by sssalah
.......... Once the sprockets and chain are fixed there's no way that cam will move backwards and thae retainer wont allow it to mave forward.
Good luck!
Well, that's what I was thinking, but I just don't remember this much play with my other cam install last year. I'll go down and put on the chain and sprocket and see what happens. Thanks
~John
Old Mar 16, 2003 | 04:18 AM
You were correct, sssalah. Once I put the sprocket on, everything lined up correctly. Guess I just never noticed the ammount of play there before. Thanks again.
~John
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
