Reinstalling rear main seal housing onto block, need RTV?
Old Mar 15, 2003 | 03:43 PM
Bryan 94 Z28's Avatar
I've got the gasket (the half circle gasket) and the seal is in the housing. But I noticed as I was screwing the bolts into the block (not torqued yet) that I could see a lot of daylight through there. I have the engine on the stand doing this, so I was looking straight down and could see a lot of light.
Obviously, I don't want an oil leak coming straight out into my clutch......how to I make certain that this thing isn't going to leak? Should I put a thin layer of RTV on the gasket that mates the seal housing to the block? Should I RTV the hell out of the joint where it meets the oil pan and block? (I was planning on doing that anyway) My main concern is the area where the housing gasket is.
Old Mar 16, 2003 | 01:12 AM
Anyone?
Old Mar 16, 2003 | 01:18 AM
Central PA Z's Avatar
According to my Haynes manual, NO RTV is to be used on the rear main seal or the "Half Circle" gasket for the housing.
Funny you should bring up this subject, though. I'll be installing my rear main as soon as I find or get an answer to my camshaft endplay question.
~John
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
