All that have taken their engine's out...
Old Mar 15, 2003 | 12:27 PM
NXz28's Avatar
When i pulled my stock motor....i left the stock exhuast manifolds on it and there was enough room to pull the motor with them still on...
I have hooker long tubes...just wondering if i'll be able to mount them before i put the motor back in the car to save some extra work....or will i have to drop the motor back in place and then install the headers?
I figured i'd save some time if i'd be able to mount the headers on the motor while its out of the car...its a lot easier then once its back in the car...
Old Mar 15, 2003 | 12:59 PM
ponyackn's Avatar
I was able to do it with my slp shorties but that may be a big difference from yours.
TTT for ya
Old Mar 15, 2003 | 02:36 PM
bad95z28's Avatar
did you pull the motor from the top or the bottom? if you took it out the bottom then you might be able to put it back in with the headers attached. If you did it from the top then you probably won't. they're not hard to get in and out anyhow when you have the motor unbolted. you'll just have to get the front end up off the ground a bit.
Old Mar 15, 2003 | 02:46 PM
96z's Avatar
96z
From the bottom yes, from the top no...
Old Mar 15, 2003 | 03:00 PM
Smoke T/A's Avatar
Exactly! No way from the top.
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Darth Xed
Sep 4, 2002 12:56 PM
Zaddiction
Aug 2, 2002 10:12 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
