middle of opti swap. questions!!
Old Mar 14, 2003 | 12:17 PM
Lightning-Killer's Avatar
94 motor. hotcam, 95+ timing cover, vented opti, HD timing set. the new timing cover seems to have a smaller seal for the water pump driveshaft, or the shaft is too big. do i need a smaller w/p driveshaft? or should i get the seals from the 2 covers swapped out?
common problem?
Brandon
Old Mar 14, 2003 | 12:28 PM
turbo_Z's Avatar
what if you opened up the seal a little bit so it fits over the shaft?
Old Mar 14, 2003 | 12:31 PM
im just trying not to damage the seal. lubed it up and used a little force but it seems to have a "lip" where the shft just wont fit through. if i take a screwdriver or something and "open it up a bit" ie stretch it, that wont do any bad damage will it?
just being careful
Brandon
Old Mar 14, 2003 | 12:37 PM
turbo_Z's Avatar
yeah you can try that. i hear that seal it really tight and you can just shave a little off the inside so it will fit over the shaft w/o ripping.
Old Mar 14, 2003 | 01:12 PM
yeah, just went and tried that. spread out the seal little more, and tapped it on but the black ring of the seal came out. the yellow "seal" i uess its called, is still on there tight. so do i just need a new seal now or am i ok? my buddy says the seal is bad now, cuase its the black ring that seals it, but it looks like it'd be a tight seal to me with the yellow ring.
Brandon
Old Mar 14, 2003 | 02:37 PM
Mtrhds94Z's Avatar
Those WP seals really are crap.. and hard to get right.. I'd say that seal is bad now, yes..
Also, as far as I know it's the same seal and same WP, shaft etc.. on both applications..
Do a search on here there's a few tips on seal install, etc..
I used the shaft coupling, cleaned well, as a tool to install..
Also, I 'flared out/opened up' the black part of the seal, [as I also found it 'too tight'... ] worked OK for me and doesn't leak...
Ruined one seal doing it, too...
In my opinion, that black part stabilizes the coupling, more than it seals it.. [they superceded the OLD seal.. I suspect they were getting ripped and distorted by the shaft 'oscillating' etc]
Best to install the seal after the TC is on, so at least you can leave the TC on..
Sergio
Jan 27, 2016 04:27 PM
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
