How to tell what kind of pushrods I have.
Old Mar 14, 2003 | 08:10 AM
Smokn '94 Z's Avatar
Question How to tell what kind of pushrods I have.
I seen the post earlier about hardend or chromoly pushrods. It reminded me to post my question. I have a set of pushrods in my garage that was thrown into a package with my heads I bought from a private seller. I was wondering if there is a way to physically tell the difference between just hardend or chromoly? Can I do anything to tell? Also they are "Comp". Just not sure which ones....
Old Mar 14, 2003 | 09:15 AM
Joe K. 96 Zeee!!'s Avatar
Go to Google and search "LT1"
Click the link titled "Rebuilding the Chevrolet LT1"
Your answer will be there. I believe you have the hardned ones, but check the site. Good info on other parts of the engine too!!
anaik's Avatar
If by "Comp" you mean Competion Cams, I would think that all they would sell are hardened ones. Call them and ask. Another way is, if you know somebody that works in a factory or a machine shop that has a Rockwell tester.
Old Mar 14, 2003 | 10:03 AM
turbo_Z's Avatar
i remember once reading you should NOT be able to scratch the hardened pushrods. now chromoly on the other hand i have no clue about. ive seen this question asked before and nobody seems to know how you can distinguish between the two. if you can weigh the pushrod accurately then i could weigh one of my 7.200"(OE) length hardened rods in a fews days when i tear into the motor with a grain scale. im not really sure if they would weigh differently or not but you could do a search around for the properties of regular and chromoly steel which might help you.
or you could call Comp and ask them.
Old Mar 14, 2003 | 11:09 AM
chesee48's Avatar
I have some sitting in my closet if that helps? Hehehe
Looks like they'll never go in
Bump for u though...
Old Mar 14, 2003 | 04:03 PM
ponyackn's Avatar
I always thought that hardened pushrods were the chromoly pushrods until now.
I bent a hardened pushrod and am now having some chromoly ones put in. These chromoly ones (TrickFlow???) have this black glossy layering, can't remember what it is called, and they don't have the ball-shaped tips at the end.
Old Mar 14, 2003 | 05:39 PM
Mad Machinist's Avatar
Take a "fine" file and give it a rub (preferably in the cutting direction of the file). If it just glances off then its a hardened rod, if not it's not.
Gooday,
Mike
Old Mar 15, 2003 | 08:32 AM
Question
Gooday,
Mike
Thanks but will that tell me if they are chromoly? Will chromoly scratch easy? Or will the file glance off like hardend steel? I have a set of hardend in my car right now. I am just wondering if these I have sitting on my bench are chromoly...
Formula Steve
Sep 19, 2023 08:31 AM
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Hal Fisher
Sep 30, 2015 09:03 PM
pepon214tx
Sep 20, 2015 04:48 PM
