Homemade CAI Help
Old Mar 13, 2003 | 10:45 PM
ibanezgod's Avatar
Homemade CAI Help
Anyone here ever make a homemade CAI setup with some PVC pipe? A kid I know did it, but I was wondering if any of you ever made one for an LT1 and how many/what size pipe/ how much pipe.... would you use to do this. I heard it works better or as good as the SLP setup.
Old Mar 13, 2003 | 10:48 PM
sideways_Into_3rd's Avatar
first thing i did with my car was make a sewer pipe CAI ..
i used 4" PVC .. but if i had to do it again i'd do it with 3" to fit the MAF properly and not have to mess with the ABS unit
just put 2 bends in it .. a 4"x9" conical K&N sitting parrallel to the ground ...
u can kinda see my ugly one here
http://www.sfu.ca/~pkavousi/cruise/IMG_0890.JPG
Old Mar 13, 2003 | 10:49 PM
1.8ttolt1's Avatar
i made one with some three inch pvc, a 45 degree elbow, a k&n cone, and some rubber couplers. really easy. sits out of engine bay so it doesn't collect hot air. easy ghetto mod.
Old Mar 13, 2003 | 11:23 PM
Lunarson's Avatar
I used some of that gray colored pvc electrical conduit, its a 3 1/2 OD. I cut about a 3rd of it off and mounted it with the k/n filter behind the headlight assembly. I fab'd a heatshield to isolated it from the engine, and a airdam underneath to direct air to it. I did have it rigged up with the filter in the bottom but I wanted it where it was easy access for filter inspection. The car still feels as fast as it was before to me .
Old Mar 13, 2003 | 11:49 PM
Twice The Fun's Avatar
this may be of SOME help.....
http://www.charm.net/~mchaney/ramair/ramair.htm
Old Mar 14, 2003 | 12:10 AM
Achilles97's Avatar
go to jegs or summit or jcwhitney and get a 90* mandrel bent pipe (3 or 4 inch), and buy the biggest K&N filter you can find that will fit. Then go to HomeDepot and get a PVC pipe rubber coupler to attach it to your MAF. If you paint it black, I swear that it will look as good as any kit out there, and it will work just as well.
$20 pipe
$35 filter
$8 coupler
Total = $63
I'll try to get some pics of the one I made.
Old Mar 15, 2003 | 10:03 AM
ibanezgod's Avatar
thanks guys...
Achilles.... If you can get some good pics that would help a lot so i can see how exactly you mounted everything.
Kinglouui
May 26, 2016 11:05 AM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
surreybrad
Aug 10, 2015 09:34 AM
