Airfoil Help
Old Mar 13, 2003 | 10:38 PM
az94z28's Avatar
Airfoil Help
Im tryin to install an airfoil on my 94 z but theres nothing between the TB ports for the bolt to mount to. Am i missing something or am i just a tool and i dont know how to install this properly. Do i have to fabricate something or what?
please help
thnx in advance
Old Mar 13, 2003 | 10:50 PM
ZDriver96's Avatar
There should be a hole on the top of your air foil. It should have came with a long bolt that u can put through that hole and into your throttle body..
You take out the black torx screws on top your your thottle body and u can see inside the throttle body... You'll see that bolt there and screw a nut on the end of that bolt.. Then your air foild is pulled into the throttle body securely.
Bobczar
Oct 23, 2015 11:22 AM
HarleyZ28
Oct 5, 2015 06:23 AM
Slayer
Aug 17, 2015 03:55 PM
BLK1997Z28
May 7, 2015 03:01 PM
Caps94ZODG
25
Oct 2, 2003 06:30 AM
