ls6 maf on lt1
Old Mar 13, 2003 | 07:24 AM
john35thss's Avatar
ls6 maf on lt1
Am building 383 superchared stroker and using stock obd1 computer. Does anyone know if any of the highflow ls1 maf's will work, calabration is not an issue since A.R.E. will be programing car.a
Old Mar 13, 2003 | 08:37 AM
kmook's Avatar
Advanced Tech Moderator
Moving to LT1 Tech...
Thank you.
Old Mar 13, 2003 | 09:51 AM
97FormulaWS-6's Avatar
Yes.. but make sure they have the Freq Vs Flow for that particular MAF....
Old Mar 17, 2003 | 07:19 PM
john35thss's Avatar
okay, but do both mass air sensors use the same plugs and same type of communication to ecm. If the only difference is the cal tables does that mean it should'nt be a problem to reprogram ecm to compensate.
Old Mar 18, 2003 | 07:04 AM
94 NO TOP Z's Avatar
How many grams of air/sec does these MAFs max out at? Higher than the stock LT1 one?
Old Mar 18, 2003 | 08:15 AM
cmillard's Avatar
I put the flow tables up a while ago on carprogrammer for the LS6 MAF, there are a couple of issues to address:
1. The LS6 maf is designed for a straight shot system, any bends in the system (which most f-bodies have) will throw the airflow to one side more than the other, the lack of a mesh screen to increase laminar flow makes this even worse.
2. The system isn't designed for blow- through metering, and have been known to break under pressure.
3. The limit to the maf reading 510 gm/s is a computational limit in the computer, not the sensor. The MAF won't change that.
4. Benefits are negligible and pretty much any other mod is guaranteed to get you more performance on a car that will be dyno calibrated.
That said:
http://www.carprogrammer.com/Z28/PCM...comparison.htm
Hope this helps,
-Christian
(stock MAF, screened, never have to worry about it causing problems.)
Old Mar 18, 2003 | 08:59 AM
Actually the MAF from GM comes with a screen, the aftermarket ones do not. I have one on my car... I have removed the screen though due to my intake setup (WS6)
Old Mar 18, 2003 | 09:02 AM
Buttercup's Avatar
Nope, factory LS6 have no screen... as Christian mentioned though the induction path is a straight shot on those cars.
Old Mar 18, 2003 | 09:22 AM
Mike Meyers's Avatar
Looks like somebody pawned a regular LS1 MAF off on you...
Old Mar 18, 2003 | 10:15 AM
Trust me it's not... Check out a GM P/N for a replacement GM 2002 Z06 MAF.... it comes with the screen...
If you look at a Z06 car there is no screen.. but the "GM Replacement" ones do come with it... I don't have the P/N off hand but I got the P/N from a Vette Messageboard where they were discussing every little aspect of the Z06 MAF. Infact I tried a bunch of different MAF curves, and gues what the only one that worked was one taken directly off of a 2002 Z06 Corvette, all the other LS1 MAFs have a different flow curve...
Old Mar 18, 2003 | 11:31 AM
RealQuick's Avatar
I'll back that up. My ZO6 MAF from LS1Speed.com had a screen in it. From the factory 01' ZO6's had them, but 02's didnt.
Old Mar 18, 2003 | 02:11 PM
gotcha.
I've got a straight in intake (ultra Z hood).... would this LS6 MAF do me any good? How much was it?
Old Mar 18, 2003 | 02:19 PM
RealQuick's Avatar
Originally posted by Mike Meyers
gotcha.
$150 at www.ls1speed.com
Old Mar 26, 2003 | 09:43 AM
Highlander's Avatar
My system maf or pcm maxes out at 471gps. How can I make it see till 512gps? Changing the tables????
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
hotrodyou1
Dec 20, 2014 10:05 PM
formula218
Dec 2, 2014 04:27 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
