what does an lt4 knock module do?
Old Mar 12, 2003 | 11:35 PM
draggerxlt1's Avatar
what is an lt4 knock module and what does it do
Old Mar 12, 2003 | 11:40 PM
z28Power's Avatar
The LT4 has louder overall noise produced by the engine (valvetrain, exhaust, and whatnot.) The knock module for the LT4s, therefore, have a higher tolerance for noise readings before pulling timing to adjust for knock. Anybody with a loud setup on their car finds this Knock module useful because it will not pull for "false knock" on their LT1 engines due to a simple loud setup, which keeps their timing correct and power up. yay!
Old Mar 12, 2003 | 11:48 PM
i just got an slp cat back system and my car is not doin well above 4.5 rpm's now could this solve my problem/ is that what its for?
Old Mar 12, 2003 | 11:52 PM
LT1ponykilla's Avatar
This could fix some of your problems. Especially since at 4500rpm and WOT with a loudmouth can be noisy. I would get it and try it out. You cant lose by getting it and its very easy to install.
I have heard you can lose about 10-15hp or more due to false knock. Losing this much power is something you can fill too.
z28Power's Avatar
Generally if all you have a is a catback system, the issue *probably* isn't with the KM pulling timing for false knock. However, the part is only like $30 and if you plan on continuing modifications (headers, top-end, etc.) you will need to get this anyway. Might as well throw it in, it takes literally 2 mins to plug in.
Old Mar 13, 2003 | 12:03 AM
cool thanx where could i pick this up at
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
