broke exhaust manifold studs leading to y-pipe, how to fix?
Old Mar 12, 2003 | 03:07 PM
anasazi's Avatar
try to get the y-pipe off the car we sheered off a stud on the manifold, and it feels like another one is sheering off as well. we have PB'LASTER on it and it still sheered off. how do we fix this? is there any way to fix the stud?
Old Mar 12, 2003 | 03:45 PM
blackbird007's Avatar
same thing happened to me. Its a good excuse to finally get headers. Well it was for me.
Old Mar 12, 2003 | 04:30 PM
COMNBYU's Avatar
ditto here too. we broke one when we were gutting the cats.
basically you have to take the manifold off and restud it. this involves tapping the "collector" part where the studs are. you should be able to use the same spot as the original stud.
it's a pain in the ***, but your only other option is to get another manifold, or get headers.
good luck!
jon
Old Mar 12, 2003 | 05:16 PM
streetbad's Avatar
Oxy acetleane torch,drill,easy out.
Old Mar 12, 2003 | 08:48 PM
blown383's Avatar
I had the same problem...you have to get it fixed or you'll induce a lean condition. The only option is to yank the manifold, drill out the stud with a carbide drill bit, and use a nut and bolt to fasten the manifold to the y-pipe. Or...just get headers. =)
-B
Old Mar 12, 2003 | 08:59 PM
anasazi's Avatar
well its leaking, i can't hear it, but at idle the RPM's lope and acceleration is crappy, missing, etc... throttle response seems fine, just missing now, sucks.
so i'm going to drive on it till like friday AM and take it to the muffler shop where they'll drill out the bolt. not sure what i want to do after that... i'm sorta kinda afraid to do the rest of the bolts cause this was the ONLY bolt in a easy-to-get-to position... maybe its just my car's time for headers, huh? but then i'd be afraid of breaking one into the head, how does one fix that?
anyways here are the pics
http://anasazi.sytes.net/pics/MVC-271S.JPG
http://anasazi.sytes.net/pics/MVC-272S.JPG
Old Mar 12, 2003 | 10:20 PM
blown383's Avatar
Just spend $10 in parts and do it yourself! You can still drill the bolt from underneath the car. However if you plan on installing headers make sure you remove the end bolts first because you'll put stress on them while removing the others and cause them to snap. Good luck!
-B
Old Mar 12, 2003 | 11:05 PM
Rodrigues's Avatar
All 6 of my Y pipe bolts broke! Chances are, they all will. I sure am glad I got headers.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
markaubuchon
Jan 14, 2015 01:48 AM
spearous
Jan 12, 2015 11:03 AM
