Problem with cutout and SES
Old Mar 12, 2003 | 01:55 PM
vhgjk123's Avatar
I have had an SES light on for a while. Its the low efficiency in bank 2. My mechanic thinks it might be the cutout. Has anyone else triggered an SES light with a cutout?
Old Mar 12, 2003 | 03:54 PM
6spdpewterZ's Avatar
nope
Old Mar 12, 2003 | 04:01 PM
2001NBMZ28's Avatar
Ditto. It's not your cut out.
Old Mar 12, 2003 | 06:10 PM
35thanniv.SS's Avatar
There is no way a cutout can set off your SES light. Might want to check out your O2 sensors. I had a problem with them one time.
Old Mar 12, 2003 | 06:59 PM
2002 NBM Bird's Avatar
Change mechanics
Old Mar 12, 2003 | 08:32 PM
ABeasst's Avatar
I bet on a bad O2 sensor I have cutouts right behind the headers and get no SES light.
Old Mar 12, 2003 | 10:17 PM
rncotton's Avatar
Bad O2 sensor.
When I had some exhaust work done, my O2 sensor failed immediately after. I guess it can get too hot when they are welding the pipes, or maybe it gets clogged with residue from the welding.
Replace the O2. If you're still under warranty, see if they will do it for you. They did mine ... didn't care that I had modified the exhaust.
Old Mar 12, 2003 | 10:47 PM
stik6shift98's Avatar
im almost positive it is an 02....if u can get the code number or the whole part then i can also tell u the side
jbrockwell
Mar 14, 2015 08:44 PM
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
Rich_z28
Sep 13, 2002 03:35 PM
Chrisdude
Jul 24, 2002 02:25 PM
