SES light
Old Mar 12, 2003 | 11:02 AM
justahoe's Avatar
SES light
I got a code 29 on my 95z. They told me it was for the air pump wiring and fuse being to small from factory, sound right? If so I do I fix it?
Old Mar 12, 2003 | 12:11 PM
cridom's Avatar
its easy put a 20amp fuse in the air pump place in the fuse box
the old one should be blown if this new one blows put a 25amp
it happened to me and i put a 20 amp and it hasnt blown for 2 weeks
Old Mar 12, 2003 | 01:00 PM
LWillmann's Avatar
I believe there was a recall for the air pump problems you both describe. The solution was to put a new air pump on it. Check into that, if I'm right, it'll cost you nothing to get it fixed right.
Old Mar 12, 2003 | 01:07 PM
LOW TRAC's Avatar
Interesting, I just replaced the 20 amp for the air pump in my 94 about 3 weeks ago. That stupid SES light was driving me nuts, no one on this board had anything to say about the air pump so it was just by chance I checked it. Thats cool though, I'll have to check the records on this car to see if its been recalled.
Old Mar 12, 2003 | 01:47 PM
justahoe's Avatar
I've already had the air pump replaced on mine for the recall, but now have this with the SES light on. I try just changing the fuse.
Old Mar 12, 2003 | 01:58 PM
RamAir95TA's Avatar
Use a larger fuse and increase the gauge wire in the AIR pump circuit, and you should stop blowing fuses.
Although the stock AIR pump retains moisture pretty well, so there's also a possibility it's saturated. Mine took a dump awhile back, so I removed the little bastard totally.
Dzmaro
May 7, 2015 09:33 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
