dry kit instalation help???
Old Mar 12, 2003 | 08:53 AM
qwick_trip's Avatar
i am installing the nos dry kit. i have the vortech air elbow. how do i install the nozzels the nut and adapter they have in the kit is ot long enough to go where the ait hole is. so how do i do it?????
Old Mar 12, 2003 | 11:06 AM
snow2000SS's Avatar
The vortec elbow is aluminum right? If it is you should be able to tap the elbow itself and put the nozzle directly in it. You will need to drill a 1/4 inch hole and then tap it with a 1/16 NPT tap.
Old Mar 12, 2003 | 11:13 AM
qwick_trip's Avatar
yeah it's aluminum, but the jet is tapered the thread gets bigger as you thread it in.
Old Mar 12, 2003 | 03:09 PM
snow2000SS's Avatar
Thats ok that is why you use an NPT tap they are a tapered thread.
Old Mar 12, 2003 | 09:26 PM
qwick_trip's Avatar
ok thanks. another thing is that air elbow was a center divider that goes all the way up to about 1in before the throttle body. is it ok to have the nozzle on one side??
Old Mar 13, 2003 | 10:15 AM
snow2000SS's Avatar
I've never seen one of those tubes up close so I'm not sure exactly what it looks like but I would put the nozzle either before or after the diveder but not in one side. On a dry kit it probably wouldn't matter too much if you did but I still wouldn't do it that way.
Old Mar 13, 2003 | 06:27 PM
35thanniv.SS's Avatar
Your installing a dry setup after the MAF sensor? How is the car going to pick up the nitrous flow?
Old Mar 13, 2003 | 06:54 PM
qwick_trip's Avatar
thats the way the kit is suppose to be installed the booster pump kicks on and adds fuel.
Old Mar 14, 2003 | 10:52 AM
snow2000SS's Avatar
35thanniv the LS1 uses the MAF to compensate for the fuel and the LT1 use a nitrous regulator that takes nitrous pressure lowers it down to around 50psi and then sends a pressure signal to the fuel pressure regulator which in creases the fuel pressure to compensate for the nitrous. It's kind of like an FMU for a super charger. Hope this helps.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
Dec 4, 2014 11:56 AM
