NEED OPINIONS auto VS stik......
which will have more hp and win a 1.4 mile run
an auto bolt on
with stall and et streets
or my stik car with no spray
but heads cam and ls6 intake
and i get the hit.....
which should win???
and how much advantage does the stall have?
thanks
an auto bolt on
which should win???
thanks
1/4 mile or 1.4 mile? Big difference there.
If it's 1/4 mile he will have the advantage off the line with the stall and slicks, where you may have the advantage uptop with H/C. But for you it will come down to how well you can drive the m6 and if you can chase him down. Just race him and put $20 in it for fun.
Lastly it's spelled stiCk.
Mark
Mark
The auto with stall will only have an advantage for the first 60-200 feet. After that, the car with the better gearing and power-to-weight ratio will win (power at the wheels). ET Streets will hurt on top end.
In a 1.4 mile race, expect speeds to exceed 150.
Umm, I'd put the $$ on the head/cam car any day. An auto is fast, but a stall won't compete with heads/cam. If the auto had heads/cam as well I'd put my money on it. Technicaly stock for stock a M6 will have more HP as the drivetrain loss is lower on an M6, but it's rather insignificant, as before I got my stall on my car I beat a couple other M6 LS1's at the strip. I tear em off the line usually, then at the end they start to catch up, but they usually don't catch up in time to cross the finish line. But either way:
heads/cam > stall
heads/cam > stall
Originally posted by stik6shift98
what about gears.....what if the auto has some sick gears in it?
Mark
tdigger9899
Sep 7, 2015 10:56 AM
Jul 17, 2015 02:47 PM
Jul 10, 2015 02:23 PM
