Hydraulic lifter problem???
Old Mar 11, 2003 | 08:40 PM
big dave's Avatar
In trying to diagnose a high rpm power loss I am wondering if the lifters are going bad. I need to know if this is normal. When the motor is cold and the lifters aren't pumped up, should you be able to rotate the rocker are back far enough to swing it completely off the valve? I am able to do this pretty easily when the motor is cold. How much tension are the springs in the lifter supposed to have? Is this normal? Thanks for any replies/help you guys can give.
Old Mar 11, 2003 | 08:54 PM
Blk94Z28LT1's Avatar
that doesn't sound right. Should be tight on the rocker arms, even cold.
Old Mar 11, 2003 | 09:13 PM
xxsaint69x's Avatar
how many miles on the springs?
Old Mar 11, 2003 | 09:33 PM
big dave's Avatar
The valvesprings are new. I've been trying to find the solution for this problem for a few months. I've changed springs, added an inline fuel pump, changed injectors and gotten programming done for them.
Old Mar 12, 2003 | 07:30 AM
grygst76's Avatar
If you can spin the rocker right off the valve, then it is time for a valve adjustment!! that is set WAY too loose and you might end up breaking things. when setting them you tighten the nust down up until you can not spin the pushrod side to side not up and down and the best bet is a quarter turn after that, you should be right on the money and if you push higher rpms that will work, if no pushing high rpms, then a half to a full turn will give you more torque low just like solid lifters
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Red_94Formula
Jan 22, 2015 12:17 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
