Arcing At Coil
Old Mar 11, 2003 | 08:37 PM
HectorM52's Avatar
Arcing At Coil
Okay, I started to hesitate and stumble so I tried to figure out what was going on. I looked at night, and boom, there it was. The little "square" metal cage that runs around the coil (this wraps around the plastic part like a "cage".) well this part had an arc on both sides as if to fill in the gap between that "cage" and the plastic part of the coil.
So I went to Advance, bought a coil and expected that to work. It didn't. So should I buy the ignition module? It is 80 bucks compared to 15 for the coil so I don't want to do that if it isn't going to work. What do you think?
Old Mar 11, 2003 | 09:40 PM
HectorM52's Avatar
No one know?
Old Mar 11, 2003 | 10:58 PM
Make sure the coil is grounded well. Be sure you have the braided ground strap from the coil stud to the chassis. Check your coil wire with an ohmmeter to be sure the resistance has not gotten way high. Check for corrosion on any terminals on the coil.
Old Mar 12, 2003 | 06:12 AM
HectorM52's Avatar
Again, the coil is brand new. It is still doing it. It is grounded. This just started and I never even touched it!!
Old Mar 12, 2003 | 07:08 AM
hairbear21's Avatar
It has to be the coil. It may have been bad from the get-go. They will replace it with no problems.
Old Mar 12, 2003 | 06:16 PM
grygst76's Avatar
if its grounding out replace the module and make sure you use the dielectric grease on it and don't touch it with your fingers or it will lose its conductivity. If it is not the module you have an electric demon in your car
Old Mar 12, 2003 | 06:33 PM
AHARTZ28's Avatar
get a GM coil or another aftermarket coil and when you put it on clean the coating they put on them where it bolts to the bracket so it is bare metal then that should work
Old Mar 12, 2003 | 07:15 PM
hsyr's Avatar
I bet the coil is just fine, its your coil wire thats causing you problems. Last fall my car would stumble down low and run rough. I opened the hood with the car running and I saw something arching by the coil. Yanked the wire off and I was suprised it was even running. The wire was all ashes on the inside of the wiring. Go get a new coil wire and see if that cures it.
Old Mar 12, 2003 | 07:41 PM
num's Avatar
num
another thing I've heard is if the coil to distributor wire gets too hot it will stumble. This happens with the ghetto wires aquired from Parts America unless you have a heat shield around it, and the boots. Even the cheap plastic wireloom conduit might help in this instance.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
