adire shriva VS. Elemental designs K series
Old Mar 11, 2003 | 06:19 PM
user guest 45's Avatar
Which one would you say is better? would one of each be enough>?
thanks,
shawn
Old Mar 11, 2003 | 06:54 PM
Red97LT1's Avatar
I have heard a shiva awhile back,the guy was running about 500 watts to it(i think) and it sounded GOOD .He only had the one 12". Now i haven't heard the elemental designs sub yet,but the same guy that recommended the shiva to me also recommends the e designs sub.
megabass's Avatar
Re: adire shriva VS. Elemental designs K series
Both are outstanding subs for the money. But it depends on how much air space you have. Shivas need LOTS of room, where e12's work in very small enclosure. That should be your main consideration. I personally tend to favor the e12. Simply because I know a guy who had a pair of shivas and went to the e12ks and said they sounded even better and hit even harder that the shivas did.
Old Mar 12, 2003 | 07:02 AM
rthompson's Avatar
both are on par with each other, just different subs...
The Shiva is more efficient and has a little more low end, the E12K can take more power, go in a smaller box and looks better... your choice, both great subs
Old Mar 12, 2003 | 02:00 PM
firebirdude's Avatar
Also, let it be known that the Shiva only comes in a dual 8 ohm config. If you plan on running only one sub...... the edk is obviously the way to go.
Old Mar 12, 2003 | 03:14 PM
megabass's Avatar
Good point
NewsBot
Sep 15, 2015 11:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
NewsBot
Aug 21, 2015 09:40 AM
karpetcm
Aug 14, 2015 03:02 PM
