Check engine triggered by catalyst code
Old Mar 10, 2003 | 09:40 PM
Sunray's Avatar
I am not sure what to do? I have checked everything the cats look new and I just put a new 80 series flowmaster on it. What else can cause the catalyst code to trigger the check engine light. All and any help would be appreciated.
Kenneth
Old Mar 10, 2003 | 09:43 PM
The specific DTC would be helpful. Plus some info about your car.
Old Mar 10, 2003 | 09:51 PM
Sunray's Avatar
1996 Z28 A4, pretty much stock other than California Highway patrol computer program. Runs great just throws the check engine light not sure the code number, however it just says catalysts. Hoep that helps you out!
Old Mar 10, 2003 | 11:44 PM
Unfortunately it does not help enough. There are over 20 different codes for the O2 sensors. The code would tell which of 4 sensors indicated a problem. I am assuming O2, since you mentioned "catalyst".
Old Mar 11, 2003 | 01:07 PM
Rearpl8tsinsite's Avatar
Just a thought....check your fuses. I had an SES light come on and Thanks to Shoebox and co traced it to be the fuse for my air pump. Probably saved me several hundred dollars. Anyways it is worth a shot.
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
danielbmx
Aug 27, 2002 11:11 PM
