Cleaning/fixing IAC?
Old Mar 10, 2003 | 05:19 PM
vodoo-chile's Avatar
Question Cleaning/fixing IAC?
I need to check my IAC and see if it is dirty or maybe even replace it. I know it is on the TB but where? Also, how do I clean or check it? Thanks,
Kyle
Old Mar 10, 2003 | 05:59 PM
bad95z28's Avatar
do a search for Shoebox and then check his website to see if he has any photos on there. he has a ton of great information. not a bad website to add to your bookmarks.
mike
Old Mar 10, 2003 | 06:22 PM
Mtrhds94Z's Avatar
IAC is on bottom of TB and a gasket set GM p/n 17113074 will cover the top and bottom gaskets.. [good time to clean the entire TB too..]
Old Mar 10, 2003 | 06:45 PM
RENE95Z's Avatar
http://csce.uark.edu/~jgbertr/rb/iac3.jpg
Straight from Shoeboxes site of wonderful knowledge.
Old Mar 10, 2003 | 08:03 PM
Hotwire's Avatar
I just tried cleaning an intermittant IAC that was sitting dormant in a transplant motor for over a year. no luck. I used sea foam, wd-40, carb and choke cleaner, etc.
The Throttle body is held on with 4 10mm bolts, the IAC is on the bottom, held on by 2 T15 torx bolts. You need to replace the gasket on the TB, IAC has rubber o-ring. If you do decide to pull it apart to clean everything, make sure you oil the IAC with clean motor oil. I just dipped my finger in a bottle and wiped it over the IAC valve. I cleaned the bore out w/ a nut driver w/ a rag wrapped around it and soaked w/ sea foam.
I got a new one from NAPA for wholesale $57, walk in price is $107.
Good luck.
Old Mar 11, 2003 | 10:07 AM
Thanks guys. I will try it on sunday.
Kyle
93 RedBird
Nov 15, 2015 08:24 AM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
tdigger9899
Sep 7, 2015 10:56 AM
lt1matt
Mar 21, 2015 07:35 PM
