Pacific Alaska, California, Hawaii, Oregon and Washington
Opinions please...
Old Mar 10, 2003 | 04:58 PM
sleeperZragtop's Avatar
Opinions please...
http://www.spohn.net/index.cfm?fusea...&productid=118
....pros and cons?
Old Mar 10, 2003 | 05:02 PM
silicuda's Avatar
Wouldn't these create rattle or some kind of noise?
Old Mar 10, 2003 | 05:32 PM
97TA-WS6-Con's Avatar
I decided NOT to go to poly bushings as I heard they are not street friendly. I gather thet DO transfer to much vibration for the comfort of a daily driver.
'Course, the mounts themselves would take some weight off.
Of course the cheapest way for me to loose some weight on the car is to go on a diet myself
CoryM's Avatar
Pros: No movement in engine when launching giving you quicker response. Cons: if its a steet car it will shake itself apart. There is nothing there to suck up the engine vibration and it will be transfered to the rest of the car (especially on a unibody). You will not be able to see out your rearview mirrors because they will shake. IMO track only, and I have a pretty lax definition of streetable. Unless you are into MAJOR hp polys will be a better solution. They dont flex much but do suck up some of the vibration. If you want solid mounts for the track but not the street use a cable or chain cinch that you leave loose for the street. Then when you want to race you just pull the lever tight and the engine will not move. Uncle used to do that when he raced for $$$.
CoryM
Old Mar 10, 2003 | 05:37 PM
CoryM's Avatar
Doing a bit of reading and it appears the technical name for the cable cinch is a "torque strap" .
CoryM
Rybar's Avatar
Exclamation
I heard that solid motor mounts for our cars causes the knock sensor to detect more knock, and thus retards the timing. I would vote against them, doesn't seem like they are worth it.
Old Mar 10, 2003 | 06:29 PM
Very good point Ryan...thanks guys
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
jackpawt883
Jul 31, 2015 08:15 AM
birdblack
Jul 8, 2015 07:23 AM
