quick lt1 swap question
Old Mar 9, 2003 | 10:34 PM
ponykiller z28's Avatar
i was just curious if the 3.8 v6 Y pipe coming off the manifold is compatible with the lt1
also is the drive shaft of the 3.8 compatible with the lt1
thanks for replies
Old Mar 10, 2003 | 10:05 AM
rickyzZ28's Avatar
I dont think the ypipe or driveshafts are the same between the 2. You will need LT1 parts for both of these.
Old Mar 10, 2003 | 10:27 AM
Pretty sure the V6 pipe would be way smaller, plus the bend configuration would probably not match anyway.
I would not trust the 2 piece driveshaft under the power of the LT1. You should be able to swap an LT1 driveshaft in without a problem, though. You will have to remove the intermediate bearing assy that is part of the 2 piece shaft you have now.
Old Mar 10, 2003 | 12:19 PM
ok thanks
rocketman051894
Jan 30, 2015 03:23 PM
cmdeshon
Jan 4, 2015 11:15 AM
Jul 4, 2005 05:00 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
