I think I just about crushed everything today....
Old Mar 9, 2003 | 01:37 PM
Rodrigues's Avatar
http://kak.com/cam/DSC00019.JPG
http://kak.com/cam/DSC00020.JPG
DONT TIGHTEN THE OIL FILTER TOO TIGHT!, I think I broke my oil pressure sender unit.
http://kak.com/cam/DSC00026.JPG
I crused that on my radiator, you think its ruined?
Old Mar 9, 2003 | 03:13 PM
Rodrigues's Avatar
ttt
Old Mar 9, 2003 | 03:25 PM
Larnach's Avatar
HOLY **** MAN! What the hell did you tighten that thing on with?
Anyway, about the radiator, take a small screwdriver and pry each one of those fins out and try to make a nice flow area. I bashed the hell out of mine with a 15lb cast iron mallet while trying to pull out my damper, I fixed it the same way I recommended and didn't have any problems.
Old Mar 9, 2003 | 04:05 PM
Looks like a demolition derby going on at your place!
If the radiator does not leak and you can get enough efficiency out of it by straightening some fins, you will survive.
Old Mar 10, 2003 | 11:25 AM
camaroSSlover's Avatar
a AK-47 is not a tool to be used on an lt1
Old Mar 10, 2003 | 11:40 AM
97Z-M6's Avatar
first: you will never work on my car.
second: iwould take the radiator off and fix best you can, then go have it pressure tested. if it has leaks let them fix it.
Old Mar 10, 2003 | 12:03 PM
Smokinsometires's Avatar
Old Mar 10, 2003 | 01:02 PM
KyleMailman's Avatar
I figured you only needed the pipe wrenches to get filters off of Saturns
STAY BACK!
got_hp?
Jul 22, 2003 08:19 PM
94formulabz
Jun 20, 2003 08:23 AM
FuryZ28
Advanced Tech
22
May 28, 2003 10:02 PM
blkss01
Mar 29, 2003 02:36 AM
