egr?
Old Mar 9, 2003 | 01:27 AM
Perfecto's Avatar
egr?
At idle my camaro vibrates really bad. Then the second I touch the gas its stops. This is the egr valve right. I figured if its not too expensive I might as well replace it even if its not the key problem, after all my car is 9 years old, so I priced it. $310 at one place and $260 at another. Has anyone ever found one for cheaper.
Old Mar 9, 2003 | 02:49 PM
ImportKILLER's Avatar
How do you figure it to be the EGR? I would be 100% sure it is the EGR first (have any codes scanned) before you invest in a new EGR.
A rough idle might indicate a bad EGR, but it should be throwing you a code if it was going bad. Having to fix a bad EGR is not cheap...there really is no way of getting around it. You can try getting one off another F-body in a junkyard but it probably is dirty too...trying to spray and clean it will only buy you a little more time and you run the risk of damaging it.
I called around locally and the best I found was high $200s...then I found some #s to some GM guys and I got it for $150. Lost that paper with the #s though...
Old Mar 11, 2003 | 10:27 PM
Perfecto's Avatar
Thats just what I heard through here once. It only does it bad while in gear at a stop.
Old Mar 12, 2003 | 03:37 AM
bunker's Avatar
If it does it in the morning aswell than it's most likely, as in when its still cold right away before it goes into closed loop
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
