writeup for A/C removal
Old Mar 9, 2003 | 12:33 AM
5H9D0W's Avatar
I was wodering how I would go about removing my A/C unit.I heard it takes off alot of weight,besides,I have T-tops. Mike
Old Mar 9, 2003 | 12:45 AM
grendal's Avatar
What does having T-tops have to do with anything? heh.
You might save 50lbs by getting the A/C out. You won't be happy about that on a hot summer day.
-Michael
Old Mar 9, 2003 | 12:47 AM
5H9D0W's Avatar
.5
grendal's Avatar
Oh yeah, also let's not forget that the AC compressor is used to defrost your windows too.... Without it, you will have a hell of a time keeping the windows defogged in moist/cool weather.
-Michael
Old Mar 9, 2003 | 12:50 AM
5H9D0W's Avatar
It's not a daily driver.Can you help or not.
Old Mar 9, 2003 | 02:19 AM
Dave 96TA's Avatar
Originally posted by 5H9D0W
.5
.4
Old Mar 9, 2003 | 02:21 AM
Javier97Z28's Avatar
Moderator
Originally posted by Dave 96TA
.4
.3
Old Mar 9, 2003 | 04:57 AM
kick Z tail out's Avatar
Thumbs down
Damn.. Watch the tude, dude.
Acquire a 1LE A/C delete idler. Swap with A/C unit. Plug lines and remove the rest of the A/C hardware at the firewall.
I don't recommend going through with it.
Old Mar 9, 2003 | 05:08 AM
Smokn '94 Z's Avatar
Exclamation
I agree!!
.3
Old Mar 9, 2003 | 07:43 AM
v7guy's Avatar
I did it, never used the A/C anyways......twice in the first two years I owned the car, that's it LOL!!!
you may very well need another belt too as the pulley is a tad smaller......do a search, there's alot of info out there
Old Mar 9, 2003 | 12:25 PM
Exclamation
I did it on my car too.. The A/C was causing sh** and I couldn't afford to work on it at the time. But if yours is working, I wouldn't do it.
It's the same size belt, BTW.
Old Mar 9, 2003 | 12:46 PM
grendal's Avatar
I had to use the defogger (with the A/C compressor) to see out the window at the DRAG STRIP two days ago....
Has little to do with whether its driven daily or not.
-Michael
Old Mar 9, 2003 | 12:52 PM
5H9D0W's Avatar
I heard it takes off 50 lbs,thats alot of weight in my opinion.The benifits of taking it off is to lose weight(more power),make room in already crammed hood,save money on gas(a/c will kill my
mpg,anymore than it already has or will be after all my mods) and I thought I would need a different belt after I took it off.Don't criticize me unless you can make a list of reasons that make the above statement lose it's luster.All I wanted was a writeup.. Mike
Old Mar 9, 2003 | 03:20 PM
Exclamation Luster B gone
Okay.
50 lbs.... That's great and all.. But in reality you will hardly see a gain in the 1/4. You just won't have your A/C, that's about all you'll accomplish.
save money on gas(a/c will kill my mpg
A/C only kills your gas mileage when you use it. Don't flip the switch, it doesn't drag... But HEY! Wait a minute. You said this wasn't a daily driver.. What the hell are you worried about gas mileage for?
No. What makes you think that? I hope you weren't thinking you're cutting that pulley out. Because your accessories have to run in the correct direction. You have to get the 1LE pulley, which is just an idler, but needs to be there to keep the correct geometry. The pulley has the same OD as the A/C unit's pulley.
Old Mar 9, 2003 | 05:36 PM
v7guy's Avatar
part no. 10115875 from Dal Slabaugh for $44.27 shipped
Napa belt part # 060578
Just looked and its actually 58 3/8 instead of the 59
And you will likely have to replace the belt, especially if it is the original,mine is EXTREMELY loose, I'm going to have to replace it, the reason being is that the belt stretches some over time,not an issue until you put the A/C delete on, regardless of what people say....If you do a search you'll find that I'm right. Or you can just wait till you do it LOL!!
