TDC for #1 cyl: timing marks aligned??
Old Mar 9, 2003 | 12:09 AM
slashz28's Avatar
hi guys just wanna be sure about something, did a search and came up inconclusive. TDC for the #1 cylinder is when the timing marks are at 6 and 12? or at 12 and 12? thank you
Old Mar 9, 2003 | 12:16 AM
12 and 12 is #1 TDC.
Old Mar 9, 2003 | 12:21 AM
slashz28's Avatar
awwww f**k i adjusted all my rockers wrong then. gonna redo them, i thought it was 6 and 12 was #1 TDC. thank you very much sir
Old Mar 9, 2003 | 12:38 AM
Beast96Z's Avatar
When your number one piston is at TDC, your top sprocket should be at 6 and bottom sprocket at 12. 12 and 12 would be 180 degrees out. Unless you got somethin goin that I am not aware of?
Old Mar 9, 2003 | 01:04 AM
slashz28's Avatar
im not asking how to align the timing marks if thats what youre thinking. its so i could adjust my rockers. i adjusted them like that, thinking #1 TDC was 6 and 12. but one things for sure, shoebox aint never wrong im pretty sure hes right cause the lifters on the #1 cyl are at the bottom of their travel now that its at 12 and 12. right or worng? thanks.
Old Mar 9, 2003 | 05:31 AM
anaik's Avatar
When the cam sprocket is at 6 and the crank sprocket is at 12 and you install the opti, which can only go on one way, the rotor will be firing #6 cylinder.
Shoebox is correct.
Old Mar 9, 2003 | 07:43 AM
That is what a lot of people think. That is #6 TDC. The 12 and 6 arrangement is merely a convenient and visually easy way to line up the dots to get the cam and crank in phase.
As Slashz28 found out with the cam sprocket at 12, the #1 lifters are now on the base of the lobes. That's the proof.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Feffman
Oct 9, 2015 05:42 AM
Hurin
Dec 13, 2014 07:38 PM
ChrisFrez
Dec 7, 2014 11:32 AM
Z284ever
57
Aug 4, 2002 03:48 PM
