Coolant in my oil!!!
Old Mar 8, 2003 | 11:18 PM
96kidss's Avatar
Angry Coolant in my oil!!!
I overheated and I know that means that I either cracked a head, my block, or blew a head gasket. Is there a way I can tell which one it is? (Without taking it to a shop)....How much would a shop charge for to do the work? IS there any way I would be able to do it myself when the most I have done is install headers? I could probably get some people to help me out but it would mostly just be me.
Craig
Old Mar 8, 2003 | 11:22 PM
TMDZ28's Avatar
blown head gasket 85% sure
Old Mar 8, 2003 | 11:26 PM
I would count on $1000+ if you take it to a shop.
Old Mar 8, 2003 | 11:32 PM
bad96firechikin's Avatar
Replace the head gaskets before doing anything....
Old Mar 8, 2003 | 11:36 PM
drop top steve's Avatar
Take the heads off and take them to a machine shop and have them "pressure tested" $30-50. if OK, check for warp, install new headgaskets and like new. Now would be a good time for a cam swap.
Old Mar 8, 2003 | 11:38 PM
unTAmedLS1's Avatar
Wait til you see the valve cover its gonna be all nice and yellow gunked up. I just blew a head gasket but somehow I ended with ported heads and a cam and a whole new valvetrain when I put it back together
Old Mar 8, 2003 | 11:41 PM
unTAmedLS1's Avatar
Oh yeah and most likely you did blow a headgasket you will also start to get a misfire code soon if you havent already from the coolant getting on your plugs and thats how you will know cuz mine was missing on # 7 and sure enough that was the plug and the only clean chamber on the head. It was clean because coolant is abrasive and actually cleans it but hurts it
Old Mar 9, 2003 | 12:06 AM
96kidss's Avatar
Thanks for all the replies. So the only way Ill be able to tell which it is is to take everything apart?
Old Mar 9, 2003 | 01:43 AM
unTAmedLS1's Avatar
No first I would take all the plugs out and look for one with coolant on it if you found one or a couple(mostlikely from same head) then I could guarantee like 95% you have a blown head gasket
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
FredM
Jun 5, 2015 05:45 AM
Nickster 7
May 1, 2015 09:04 PM
Sandersen511
Jan 13, 2015 03:49 PM
