Last ditch effort....cd player power advice please!!!
Old Mar 8, 2003 | 08:28 PM
Kix's Avatar
Kix
To start off, I have tried posting to car audio section, but this is not a custom question I guess, no replies. I have been having trouble with my factory (94) bose headunit flashing off and on. Thought it might be the cd player calling it quits, so I tried my aftermarket one, though I knew it wouldn't sound right. That one flashed off and on too. The problem is the constant and ignition power wires seems to have constistent 12.5V power when they are supposed to. And the ground is fine. Any ideas????? Do I need to check the current somehow? TIA
Old Mar 8, 2003 | 08:40 PM
NineSevenWS6's Avatar
What do you mean flashing on and off? Losing power? Check to be sure the harness/conections are solid. Make sure both 12vC and 12vS both have 12.6 car off and about 14v+ when running..
Old Mar 9, 2003 | 01:52 PM
fbird95's Avatar
Could be a problem with the wire itself, If it keeps up, run a new power line to the radio and splice it to the power wire going into the harness. See if this solves the probelm.
Old Mar 9, 2003 | 02:19 PM
CODY BEHNKE's Avatar
Check the power at the harness back where the wire enters it, GM harness pins like to wiggle out or loosen.
Jun 6, 2015 08:27 AM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
94Z28LS1toLT1
Mar 10, 2015 09:52 PM
