Anyone have the XE 230/236 cam? Questions asked...
Old Mar 8, 2003 | 07:32 PM
ucrazymonkey's Avatar
I have a 97 TA that is set-up to take an aftermarket cam. The heads are full of goodies. Ex: 10308-1 Crane Spring Retainer Kit, Summit Guide Plates, Summit 1.6 RR's with 7/16 Studs, ARP Screw-In-Studs, Comp Cam 5/16 Hardened Push Rods, Felpro Performance Gaskets, 3 angle Valve Job and ARP Head Bolts. They do have the stock size valves and have had no porting work done at all.
I have a 10" TCI 2800 Stall Converter, Hooker Shorty Headers, 3.73 Gears, E.T. Streets and OBD1 LT1 Edit. So basically I am set-up for a larger cam.
My question is would this cam be the best suited for me? I dont want to rev to the moon and would like to make most power in the begiining and in the middle. Would like a lopy idle and just ***** out. Most of the time is spent at the strip whenever possible.
What do you guys think?
Old Mar 8, 2003 | 08:03 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Anyone have the XE 230/236 cam? Questions asked...
ken mook has it if i remember correctly.
he posted a dyno chart somewhere
sounds like a great cam for you
Old Mar 8, 2003 | 09:58 PM
Ken95Z28's Avatar
Just installed it and ran it this weekend.
11.70@114.88 that's with the DA at 2300ft.
Video Run
11.70 Run
Old Mar 8, 2003 | 10:03 PM
Mr. T's Z's Avatar
Man KEN you keep making me JEALOUS!!! I can't wait to get mine together ahhhhhhhhhhhhhhh........
Tyler
LOVE MY 111 LSA
Old Mar 8, 2003 | 11:36 PM
unTAmedLS1's Avatar
Is there a significant difference between the 230/236 and the 224/230 I hope not because I dont wanna hear "you should have gone bigger" I just got 1.6rrs, valvesprings, xe 224/230 112 LSA, hardened pushrods, and ported and polished head and also some jethot lts
Old Mar 9, 2003 | 12:50 AM
Beast96Z's Avatar
If you feel that maybe you should have gone bigger, you should have. The 230/236 should work nicely in your set-up. XE cams make good low-end so you won't have to rev high.
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
slocody
Feb 10, 2003 01:04 PM
