fuel lines need help fast????
Old Mar 7, 2003 | 11:53 PM
qwick_trip's Avatar
ok there are three fuel lines that run under the drivers side floor. they are plastic then they hook in to metal. well on the plastic part i got a very very very small hole in one line. i called around and was told how to fix it. the told me to go to autozone or a hardware store and the have metal pieces of tubing that you slide into each end of the tubing. is this the best way to fix my problom? or should i replace them? how hard is it becausefrom what i could see is that they dissapear into the frame???
Old Mar 8, 2003 | 12:51 AM
25th-transam's Avatar
Re: fuel lines need help fast????
I had a hole in a fuel line, in the engine bay. What I did was cut the line in half to allow me to slide a rubber piece over the two ends of the hose and join them together. I forget the exact details of the hose but it was for fuel lines i think though, thought this might give ya some help maybe.
Kurt
Old Mar 8, 2003 | 09:49 AM
qwick_trip's Avatar
ok this morning i went out and took off the inner black part of the fender. the lines would be easy to replace i think, but how much are the lines from the engine back to the steel lines???? or should i just use the metal repair kit where the line is broke?? will repairing it that wy work good???? thanks
Old Mar 8, 2003 | 10:44 AM
The lines come as a unit for all 3.
1994-1997 front flexible fuel supply lines p/n 10258441
gmpartdirect reference price $42.67
GM recommends replacing the nylon line if needed but that does not mean it cannot be repaired. The fuel supply line is 3/8" and the return line is 5/16".
Old Mar 8, 2003 | 11:38 AM
qwick_trip's Avatar
does the kit come with the ends or do i have to reuse mine or buy new ones? since there only $42 i should just replace them rather than repair them right?
87Aerocoupe
Mar 20, 2015 01:23 AM
maybe2fast
Feb 5, 2015 05:14 AM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
