car feels weak
Old Mar 7, 2003 | 12:45 PM
PumpkinKingZ28's Avatar
car feels weak
ive noticed recently that my car isnt pulling as hard as i think it should. I thought it was just me so i had a friend try it out and he thinks it does feel a bit weak. He said it may be mis firing, my other friend had this happen to him aso. i thought it was the clutch but when i get on it, its not doing clutch symptoms like just reving real high while in gear. we think that it may be the spark plugs, i guess it would be a tune up. how much would replacing the spark plugs and wires cost? does this sound like a possibility? and if so is it common? and also i think my alternator is going out, would this play a role in it? thanks for the help
Old Mar 7, 2003 | 12:50 PM
Pandamonkey's Avatar
It's no big deal - you just need some Nitrous.
If you haven't done a tuneup in a while - that would be the first place to go. Use some seafoam also.
I don't think your alternator will cause a power loss. You have have it checked for free if you take it out of the car and bring it to a local shop if you so desire.
Old Mar 7, 2003 | 12:56 PM
thanks, but what exactly is seafoam,, and can i do a tune up by myself? i havnt done one personaly on the car, but maybe the previous owner did(doubt it) . Is it expensive. i think its just the spark plugs.
Old Mar 7, 2003 | 01:04 PM
kevkop94TA's Avatar
Cool
Do a tuneup and go from there. Do it yourself though. It's a lot cheaper, realtively easy, and you'll know its done right. I would do the seafoam, replace plugs, wires, coil, air and fuel filter, and go from there. Maybe change 02 sensers, but they're a little more expensive, and chances are they are ok.
There was a thread about Seafoam just the other day by ACAenterprises or something like that. Just do a search, he's got a great write up on how to do it as well. Best way to learn about your car is to do as much work as possible yourself with help from friends/family.
Old Mar 7, 2003 | 01:05 PM
My Mighty White 95 Z28's Avatar
You might wanna do the Seafoam first before you change plugs. Here is a link which will talk about seafoam and the procedures to using it:http://w3.one.net/~roz/cars/z28/seafoam.html. Good luck
Old Mar 7, 2003 | 01:09 PM
Hal Fisher's Avatar
Is it because of warmer temperatures? A cold 40 degree night will give you all kinds of power over a 70 degree day.
Hal
Old Mar 7, 2003 | 02:26 PM
thanks guys, i plan on now replacing the plugs and wires first and see what that does. im going to read up on seafoam and possibly do that. whats a good brand of spark plug, i heard the v 12 or something like that?
Old Mar 7, 2003 | 02:39 PM
do yall think it would be a bad idea to do seafoam before replacing the wires and plugs?
Old Mar 7, 2003 | 03:24 PM
leadfoot94's Avatar
You should definitely do the Seafoam before installing new plugs and wires, otherwise they will get real dirty from all of the Carbon, and other grime the seafoam has cleaned out.
Old Mar 7, 2003 | 03:46 PM
kevkop94TA's Avatar
What he said.
For plugs I'd go with NGK plugs. TR 55's gapped at .050 are the plugs of choice on this board. Pretty cheap too. I have em, and like em. I noticed it ideled and revved smoother when I replaced the plugs and wire.
calaban
May 18, 2020 06:43 PM
ANDYZ28
Dec 29, 2014 09:13 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
JasonD
Jul 15, 2002 02:17 PM
