Shark vs Piranha vs NOS Fogger Nozzles
Old Mar 7, 2003 | 02:11 AM
InjectedSS's Avatar
like the sub says... which one out of the 3 is best?
Old Mar 7, 2003 | 03:58 AM
texlurch's Avatar
I have used the NOS and the Shark, with the NX jetting the Shark seems to mix better. I can tell the difference in the way the motor sounds when you hit it. (no, really!! )
Old Mar 7, 2003 | 12:11 PM
CustomN2O's Avatar
The NX nozzle is by far superior to the NOS nozzle. Much better atomization, and tuneups. As far as between the shark and the pirhana, it really depends on the manifold you are using. If its a single nozzle deal, mounted before the throttle body, I would use the Shark. If its a direct port kit, on a stock manifold with clearance problems, I would use the pirhana. The difference is just the size. The Shark uses 1/8 pipe, and the Pirhana uses 1/16. The Shark will go above 500hp, and the Pirhana is only good till 500. Hope this helps.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
FryedClutch
Sep 1, 2015 08:24 AM
cardemo16
Aug 24, 2015 01:04 AM
colts0455
Jul 20, 2015 09:52 AM
