Pacific Alaska, California, Hawaii, Oregon and Washington
What gap's are you running?
Old Mar 7, 2003 | 01:32 AM
sleeperZragtop's Avatar
With all the modding going on, do you guys stick with the gap or go higher or lower than stock....thanks
Mike
Old Mar 7, 2003 | 01:36 AM
Punisha69's Avatar
well
you'd wanna go lower if anything
but i run stock TR55 gaps
Old Mar 7, 2003 | 01:58 AM
NiteRider's Avatar
Originally posted by Punisha69
well
Same here, left the gap alone.
Old Mar 7, 2003 | 02:21 AM
bunker's Avatar
with a stall you want a bit smaller gap, high rpm low load = lower fuel = easy spark blow out when cruising, thats what a tunner once told me.
Old Mar 7, 2003 | 02:22 AM
sideways_Into_3rd's Avatar
leave the gap alone . unless ur doing major compression change .. or adding FI or N2O ...
Old Mar 7, 2003 | 02:45 AM
..any technical agruments?...thanks
Old Mar 7, 2003 | 03:52 AM
Punisha69's Avatar
Yes.
I'm SmRt
Old Mar 7, 2003 | 09:10 AM
BPS's Avatar
BPS
I run autolight 103's with a gap of .035
Old Mar 7, 2003 | 10:01 AM
bunker's Avatar
No I'd have the gap at .045
Old Mar 7, 2003 | 11:26 AM
JD30thZ28's Avatar
Wink
I run NGK TR-6 at .038, for the N20
Old Mar 7, 2003 | 12:46 PM
Draco's Avatar
You lower gap to reduce the chances of detonation by keeing the combustion chamber cooler. You also do it to reduce blowing out the spark on high compression/FI setups.
You raise gap in lower comrpession engines to ensure that the fuel mixture is properly ignited, since the combustion chamber temps need to be higher.
Since you haven't significantly changed your compression, and you haven't added forced induction, I would stick to the stock gap of 0.05, or possibly lean towards Matts suggestion of 0.045.
Old Mar 7, 2003 | 01:45 PM
That's what I was looking for...thanks Craig...and everyone else's imput
Old Mar 7, 2003 | 03:35 PM
Zedzag's Avatar
I sent you a PM MIke.
Old Mar 7, 2003 | 04:23 PM
Black Robe's Avatar
Another view on plug gaps...
A little more info on spark plug gaps:
1. The bigger the gap, the more maximum voltage required to start the flow of charge. The quality of the ignition system components determines when misfiring will occur.
2. The bigger the gap, the more area of combustible charge exposed to the spark energy. Generally, the bigger gap you run, the better your chances of good operation.. but, see 1. above
3. With lean the mixtures, more gap is a good way to help ensure adequate ignition of the weak fuel/air charge.
4. The heat of the spark itself has no effect on combustion chamber temperature. A spark plug gets it's heat from the burning of gases in the cylinder, then rejects the excess to the metal/coolant of the cylinder head
5. C/chamber temperature is a result of intake manifold pressure, fuel/air mixture, throttle position, engine RPM, other combustion conditions (eg. fuel anti-knock capabilities) and the engine's cooling system efficiency
That end's today's sermon, er, lesson...
Old Mar 7, 2003 | 10:53 PM
bunker's Avatar
Yep.
