z28 lt1 or corvette lt1
Old Mar 6, 2003 | 11:44 PM
killer-of-pony's Avatar
ok guys heres the deal. i bought a 93 z28 the guy i bought it from replaced the engine 15 grand ago.( because jiffy lube forgot to put the oil drain plug back in!!!) so he put a 97 lt1 in it. he said the new engine was a corvette with zero miles. i saw the dealer recipts and still have them. all the recipts say are new motor.....$3500. so how can i tell if it is a corvette engine.and if it is what are the proformance diff?
Old Mar 6, 2003 | 11:57 PM
cef97ws6's Avatar
Some others might chime in and have a better method but the only sure fire way I can think of is if it is a 2 or 4 bolt main block. As for performance probably not noticeable.
Old Mar 7, 2003 | 12:01 AM
ddr698's Avatar
Corvette engines have four bolt mains. If he put in a crate motor the fuel lines will enter/exit on the pass. instead of the drivers like on f-bodys. Also acc. will be loaded up to the drivers side. Seeing how probably only internals were replaced, the only way i know to tell the diff is the vette motor has 4 bolt mains.
Corvettes were rated 300hp stock and i think F-bodys were rated at 270-285hp? Im not sure where the power increase comes from. I think the cam grinds were slightly changed and maybe programming...im not sure, someone else is probably better at answering that.
Old Mar 7, 2003 | 12:15 AM
atljar's Avatar
Not all vettes are 4 bolt mains, i have seen some personally which arent. So thats not failproof.
Vettes accessories mount on the other side of the engine, but i would think that you would have to convert to the f-body style to put in a f-body though.
I really dont know how you would tell, but what difference does it make in the long run?
Old Mar 7, 2003 | 12:21 AM
slashz28's Avatar
werent all the lt1 crate engines the 4 bolt main ones? i thought i had read that somewhere, not that i actually know
Old Mar 7, 2003 | 12:55 AM
Dr.Mudge's Avatar
In 97 the Vette was an LS1.
Old Mar 7, 2003 | 01:08 AM
MysticTeal 95 V6's Avatar
if he says it was a '97 engine... and its an LT1 then what he said should answer your question
What does it say on the receipt? crate engine or what.
Old Mar 7, 2003 | 02:19 AM
kgkern01's Avatar
Is the crate engine basically a Vette engine? My car had an engine replaced by a dealer by the previous owner, the paperwork from the dealer says pn#12524896 ENG-LT1GW I was just wondering the same if mine is the 275, 285, or 300 hp version, the engine was replaced in April 2000.
Old Mar 7, 2003 | 03:26 AM
Calli's Avatar
a 93 z28 with a 97 year lt1... does this engine have a MAF sensor or is it speed density still ?
Old Mar 7, 2003 | 07:23 AM
97Z-M6's Avatar
it would have to still have the speed density (unless coverted). the engines are the same. just droped a new one in a hooked up everything that use still on the car, like all accessories, pullies. they probably just replace the block and new heads.
and it wasnt a 97 vete engine. it may be a 97 lt1 engine. but if it were a 97 engine it would be a ls1, as said above.
Old Mar 7, 2003 | 10:26 AM
bandit1's Avatar
97 corvette engine=LS1......
97LT1 would be a z28 engine.
Old Mar 7, 2003 | 10:28 AM
Mtrhds94Z's Avatar
I also recall seeing this info somewhere...
Old Mar 7, 2003 | 10:59 AM
neil350's Avatar
GM sells crate LT1 350 4 Bolts, they are only short blocks and retail at like 1700 or some thing like that. Vettes are rated more but thats not due to the engine, rather better intake/exhaust. I can't fid the part # you gave, I'm sure you just got a replacement LT1. The dealer would just replace the motor not the engine management system. C'mon now guys
Old Mar 7, 2003 | 11:24 AM
PatriotTA's Avatar
I think all three engines made the same HP at the crank. The 275 hp version (F-cars) had a single-cat y-pipe, and the 285 hp (F-car) had a dual cat y-pipe. The 300 hp (vette) had freer flowing exhaust and intake. Ram Air options also add some hp. If you are curious, get your car dynoed.
Old Mar 7, 2003 | 11:26 AM
Dr.Mudge's Avatar
There were slightly different cams through the years, but the Vette had dual exaust, so don't dream too hard about having a 300 HP engine.
