Can't separate T-56 from Bellhousing...
Old Mar 6, 2003 | 07:58 PM
Dave88LX's Avatar
'97 Formula.
I have the 8 bolts out. I have the engine supported by the oil pan. I've got a floor jack w/ tranny plate under the tranny supporting it.
I shooke the **** outta the tranny but it doesn't seem to want to separate. Am I missing something here?
Old Mar 6, 2003 | 08:01 PM
Highlander's Avatar
If I remember... yes they were just 8 bolts.. but you need to line up correctly the tranny.. if its a bit tilted the input shaft will make pressure on the pressure plate and it will not come off... Dont shake the HLL out of it... treat it softly and specially with a tranny lifter
Old Mar 6, 2003 | 08:03 PM
xxsaint69x's Avatar
it doesnt want to come out becuse the shift fork is not desangaged (sp) You need to grab it and pull it down/left if i remember corectly
Old Mar 6, 2003 | 08:06 PM
Dave88LX's Avatar
I'm following along w/ the directions from zachz28.8m.com
I've got a jack w/ a tranny type plate thing on it, it's supported pretty well. I was trying to shake it loose heh.
I did remove the clutch cylinder, and pull the fork down.
Old Mar 6, 2003 | 08:08 PM
Highlander's Avatar
YESS YESS YESS to xxsaint69x you listen...
just remove the slave cylinder and put you finger in it.. you will fill a small valley where you can sort of grab the fork and dissengage it... that is it
Old Mar 6, 2003 | 08:10 PM
Highlander's Avatar
If you removed the fork shift then just line it up and shake it easier with a tranny jack...
Old Mar 6, 2003 | 08:17 PM
xxsaint69x's Avatar
if it doesnt want to come out the fork isnt all the way out or maybe u didnt get all the bolts out
Old Mar 6, 2003 | 08:30 PM
Dave88LX's Avatar
Well, I've got 8 bolts in my hand, and the fork is pulled out.
Actually 7 in my hand, the 8th I couldn't grab, but, it's out LOL (top right).
What the problem is, is the METAL between the two won't separate. Like, stuck togother! I try shaking, but it won't "crack".
Old Mar 6, 2003 | 08:32 PM
Highlander's Avatar
Use a screw driver or such thing...
Old Mar 6, 2003 | 08:53 PM
Dave88LX's Avatar
Just to clarify, I'm going for seam A, won't break apart.
Old Mar 6, 2003 | 08:56 PM
Russtebo's Avatar
This exact same thing happened to me even after I pulled the clutch fork, know what it was? The clutch fork... Pull down on it again, sometime you think it's disengaged but it's not....
Old Mar 6, 2003 | 09:19 PM
Cory_SS's Avatar
If I remember correctly there are dowl pins on the bellhousing....so you will need to do some prying to break it loose
you've got the fork out...so there should be nothing else holding it in
Old Mar 6, 2003 | 09:46 PM
Dave88LX's Avatar
It kinda seems like there's dowels or something, but nothing visible from the outside. I said **** the jack and creeper, and just tried to manhandle it out, I was able to get it to rock a little, pop free to crack open a tiny slot, but, nothing that got it out
Old Mar 6, 2003 | 09:52 PM
Cory_SS's Avatar
...man I've had the same problem you're having, and you just need to break it loose from the dowel pins
It's like wrestling an alligator till you get it loose...best I can explain it
Old Mar 6, 2003 | 09:57 PM
Cory_SS's Avatar
...forgot to add that it will help greatly if you take the pressure off the input shaft since the tranny sags down...so what you have to do is jack up the rear of the tranny and pry where you have seam A in your pic
I did'nt have a jack, just an extra set of hands but thats all it took...get that weight off the input shaft and get the dowels out of a bind, then it should pop loose
